Hi there, let's me breakdown some history detail. The machine was replaced its glass scale on the X-axis after the previous one was broken. The X-axis is driven by the linear motor. After making the new change, when we try to move the axis, the error 411, 475, 1071 always show up. These happen sometimes at the lowest feedrate and the axis is not able to move at higher feedrate.
What we've tried
- Check motor's wires (good)
- Move the axis manually (no obstacle - good)
- Try to adjust the gap between the linear motor and permanent magnet but no hope
The machine components
- FANUC LINEAR MOTOR LiS-B series
- Heidenhain glass scale
The diagnostic panel might have some noticed errors but I have no ideas. I'm new to this.
Param 0353 Servo DGN Data: X-axis value, compared to others, fluctuates even being idle
Param 0303 Servo Error is obviously high and getting many higher when axis moving.
Big Thanks in advance
