547,519 active members*
2,054 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > HEIDENHAIN > HEIDENHAIN -> TNC > TNC 2500 b Backup Parameters Issue - What is the program number
    Aug 2020
    10
    Long time lurker first time poster,
    I am trying to export the Machine Parameters using TNC Server. cant find parameter file program number under which the machine parameters
    are stored
    I have had a Bridgeport VMC 1000 -22 (circa 1994)
    My machine parameters are all present and the machine for the most part is running well, will post them up here once i can get them backed up
    i have gotten as far as
    Below is the instructions on how to do it but i cant seem to find the "program number"
    Press "MOD" until "Code Number" is displayed
    Enter "95148" in CODE NUMBER
    Press "ENT" to Activate MP mode
    Press "EXT" & the press "ENT" to prepare TNC for data output
    Enter the program number under which the machine parameters
    are stored
    Press "ENT" to Start data transfer
    When the data transfer is finished, the dialog EXTERNAL DATA OUTPUT
    is cleared.
    Pres "END" to exit MP mode
    attached is an extract from the manual
    Aug 2020
    10
    Re: TNC 2500 b Backup Parameters Issue - What is the program number
    FIXED
    hope this helps someone else with similar issues
    Made one very small adjustment to the instructions and got it to work,
    Press "NOENT" to create new file
    are stored
    is cleared.
  1. Bridgeport Interact 300 TNC 2500 parameters lost
    By Bensa in forum Bridgeport / Hardinge Mills
    Last Post: 03-06-2018, 11:09 AM
  2. Bridgeport Interact 308 + Heidenhaim TNC 2500 | Parameters
    By joe72lp in forum Bridgeport / Hardinge Mills
    Last Post: 11-16-2016, 04:15 PM
  3. Bridgeport Interact 308 + Heidenhaim TNC 2500 | Parameters
    By joe72lp in forum SERVICE FOR CNC-MACHINES
    Last Post: 10-19-2016, 09:12 PM
  4. Replies: 1
    Last Post: 11-28-2008, 03:22 PM
  5. interact 1 mk2 tnc 2500 parameters
    By markjackson in forum Bridgeport / Hardinge Mills
    Last Post: 06-29-2007, 01:05 AM
