589,196 active members*
7,398 visitors online*
    TNG V2 and Arduino scripting
    I have recently upgraded to TNG V2 from the older CNCUSB s/w. I have a key pad which amongst other things I use for jogging. On the CNCUSB software I could treat the 0 key as a shift key, but that doesn't seem possible in TNG V2. I am considering using an Arduino to interface the keypad. I have implemented the Arduino project as a learning exercise, and it basically works.
    I have noticed that if I go to File>Settings, make a change and then Save, the script appears to have stopped working - its as though the listener has been inhibited.
    Is this the intention or is it a bug?
    Is there a way of restarting the script?
    Are there other commands which have this effect?
    Any help would be appreciated.
    Mar 2017
    1345
    Re: TNG V2 and Arduino scripting
    Serial listener stops working. This is a bug that will be fixed.
  1. Replies: 3
    Last Post: 05-16-2023, 06:07 PM
  2. Scripting a Moveable Tool Setter in TNG
    By HobbyCAD in forum PlanetCNC
    Last Post: 03-23-2022, 10:42 AM
  3. Scripting in TNG
    By Eatonbrayer in forum PlanetCNC
    Last Post: 10-28-2018, 05:05 PM
