541,109 active members*
3,395 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Tomatech TAC2005M cnc controller retrofit. SZ-GH1000MC
Results 1 to 5 of 5
    Junior Member
    Sep 2011
    18
    My old Arix CNC60 milling machine controller has finally died. It put up a good fight over the years but this time its down for the count.
    For the retrofit, I have chosen the Tomatech TAC2005M controller. I couldn't find much info regarding this control. From the small amount I could find on the internet I thought it was worth a shot. I have previously fitted an Adtech controller to my lathe and while it is good enough to use, I figured I'd be wise to see if this thing is any better.
    Anyone else got experience with tomatech?
    Junior Member
    Sep 2011
    18
    Re: Tomatech TAC2005M cnc controller retrofit. SZ-GH1000MC
    Small update. I have been wiring I/O the last couple of nights. The chinglish manual supplied with the kit is for an older version of a lathe controller. Not very helpful.
    I downloaded what I believe is the correct manual and its not much better. I/O page in manual is completely different to the diagnostic page in the machine. What's more surprising, the inputs are labelled incorrectly in the controller as well. Its been very confusing but I made some progress.
    This controller has deceleration switch inputs for homing. The over travel switches are supposed to be wired into the E-stop circuit. I don't like that much. The diagnostic page has over travel inputs listed but they are actually used in a digital matrix for the feed override switch! It took me a while to figure that out.
    My Adtech controller on my lathe has user configurable I/O which is much more user friendly.
    I haven't been able to figure out how to change parameters yet either. There's 3 levels of passwords!
    None of these issues are unexpected, I'll keep at it!
    Junior Member
    Sep 2011
    18
    I've been very busy working on this machine. It's up and running now I haven't cut any metal yet but it is cycling programs without (obvious) issue.
    Kevin at tomatech has been very helpful with support emails. I had some issues with homing but that was quickly sorted out. Parameter access was locked with a very long password but that is fixed now to.
    It runs much quieter and faster with the AC servos (also tomatech). It easily charged thru mastercam X8 generated high speed hybrid toolpaths.
    I am looking forward to making some swarf asap!
    So far I am impressed. I will update after doing some cutting!
    Junior Member
    Sep 2011
    18
    Cut some metal for the first time tonight! Tomatech appears to work very well. I'm happy!
    Junior Member
    Sep 2011
    18
    Talking Re: Tomatech TAC2005M cnc controller retrofit. SZ-GH1000MC
    Finishing pass completed
    https://www.youtube.com/watch?v=4GkV17H6V_I
    Some final tuning to do but machine is working well.
  1. MPG's Vistacnc MP-2's, Tomatech 2004m controller
    By pescadoman in forum Ebay Ads here
    Last Post: 03-14-2020, 09:31 AM
  2. Retrofit a good controller to Laguna IQ Pro
    By vwankerl in forum DIY CNC Router Table Machines
    Last Post: 02-24-2020, 04:25 AM
  3. want to retrofit camtech routemaster52 with a new controller
    By avengine in forum General CNC Machine Related Electronics
    Last Post: 08-10-2017, 10:59 PM
  4. Galil DMC-1050 controller retrofit
    By Jmhx2 in forum Controller & Computer Solutions
    Last Post: 09-14-2014, 04:59 AM
  5. Looking for CNC Retrofit controller suggestions
    By pmitchel75 in forum Bridgeport / Hardinge Mills
    Last Post: 07-09-2010, 02:55 PM
