544,051 active members*
1,832 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Tool for Cutting 2 1/2" Thick Fiberglass/Aluminum Honeycomb Core
    Nov 2015
    Question Tool for Cutting 2 1/2" Thick Fiberglass/Aluminum Honeycomb Core
    I have several 4'x8' sheets of 2 1/2" thick fiberglass skinned aluminum honeycomb core panels I need to cut into ovals. They are going to be the substrate for some stone and marble tile tables I am making.
    Any recommendations for which tool to use for cutting these? I don't have any tools long enough to cut through these.
    Gold Member
    Apr 2004
    5337
    Re: Tool for Cutting 2 1/2" Thick Fiberglass/Aluminum Honeycomb Core
    Sounds like a job for an abrasive water-jet machine.
    Andrew Werby
    Website
    Nov 2015
    Quote Originally Posted by awerby View Post
    Don't have one of those lying around.
    I found a tool I didn't even know I had that worked well. It is a 1/2 shank hogging bit with a 2 3/16" cutting depth, (Whiteside RU5218H). That is a little shy of the 2 1/2" cutting depth required. I cut it in two passes, and for the second pass, the top part of the bit above the flutes, was slightly below the surface of the material. But, it worked very well actually.
  1. Cutting 1" thick aluminum on CNC
    By Matthew_ in forum DIY CNC Router Table Machines
    Last Post: 12-12-2017, 02:15 AM
  2. Freezing aluminum honeycomb core
    By jberger in forum Composites, Exotic Metals etc
    Last Post: 01-22-2016, 08:02 AM
  3. Replies: 5
    Last Post: 09-12-2012, 03:09 PM
  4. Cutting 1/4" thick melamine with MDF core
    By BuckeyenNJ in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 06-10-2012, 05:51 PM
  5. I keep dulling bits cutting fiberglass sheets (Honeycomb Composite panels)
    By animuL in forum General Material Machining Solutions
    Last Post: 01-29-2008, 06:22 PM
