585,996 active members*
4,366 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Tool length offset table in combination with undefined tool
    Feb 2006
    82
    Guys
    Sorry if this has been asked- Im not finding much via search engines-
    Core issue is that Im running a Tormach Tool System on a mill I converted to CNC- which as most of you know fixes Z well enough to permit use of a tool length table without referencing tools to some external device each tool change. Im running MACH3 to control this machine.
    In a case where I'm running a larger program, and have a need for some random tool that is rarely used (no TTS holder for it- where all are allocated to the frequently needed tools in the project), and need to set the depth for that manually during the program cycle, how do I best accomplish that? I cannot simply touch off the tool, leaving its table length entry as zero, and zeroing the DRO for that coordinate system, since that would screw up the coordinate system for the other tooling (based on some master tool…).
    Am I better off dynamically populating the tool length offset in the table for that (uncommonly-used tool)? Am I better off just copying X and Y values from the working coordinate system (G54) to some other (i.e. G55), and then zeroing Z there just for that tool, with a coordinate system change in the code? That seems a huge hassle.
    I just don’t know how people deal with this- where maybe you find that a tool used mid-program is damaged and needs to be replaced before insert. There must be a way that doesn’t require a program restart/run-from-here to deal with it, but I don’t see any simple way to do this that doesn’t require rezeroing the coordinate system after the use of the ‘underdefined’ tool…
    Any help is much appreciated
    Best
    Jun 2011
    692
    Re: Tool length offset table in combination with undefined tool
    I hope you find an answer (unfortunately I don't have one for you.)
    A common use case for this would be if you're using multiple drills in one chuck in a cycle.
    One workaround, depending on how much accuracy you need and your holder type is to loosely put the tool in the holder and zero the machine (work coordinates) on top of the stock before tightening the holder.
    I think there are macro workarounds as well, where the macro will save the Z offset coordinate to a variable when you zero the tool, then recall that Z offset when you switch to the next tool.
    Mar 2003
    35538
    You could write a custom M6 macro. Keep your TTS tools numbered say 1-100. And your non TTS tools 101 and up.
    Have the tool change macro stop the code if the tool # is greater than 100, so you can zero the Z axis. And have it also stop when it goes back to TTS tools, so you can re-define their Z zero.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Replies: 6
    Last Post: 06-27-2015, 10:04 PM
  2. Tool Length Offset Tool Setter
    By CNCneeds in forum News Announcements
    Last Post: 01-03-2014, 06:27 PM
  3. set up tool length offset and ref tool on mill
    By buklattt in forum CNC Machining Centers
    Last Post: 04-01-2012, 05:01 PM
  4. Need help with tool length offset
    By panaceabea in forum Haas Mills
    Last Post: 03-04-2009, 08:07 PM
  5. Tool Length offset?
    By cncuser1 in forum G-Code Programing
    Last Post: 08-31-2007, 02:59 AM
