585,977 active members*
4,708 visitors online*
Results 1 to 6 of 6
    Jan 2005
    49
    tool length to long
    just took delivery of a new nexus 200 quick turn all well and good if you knew where all the menus and buttons are. The problem is we got a tube sticking out of chuck 6.5", we need to drill this 1 3/16 dia, the drill is out 7.5". When we take tool length using tool eye we get an error telling us the length is to long.
    Mazak tells us this is a safety issue so the drill will not collide with machine, but when moving the turret around in manual mode to check, the drill never approaches the machine bulkhead. Any help
    Mar 2005
    988
    Not sure that Mazak understood your problem completely...
    If I had to guess (don't do too much with lathes)... Interference checks are having an issue with collision. If you're really that far away from the anything, then perhaps your parameters need adjusting for the interference areas. It might be set for max or extreme coniditions (oversized chuck, short chucks, etc). Are you using Mazatrol or EIA? I will assume Mazatrol won't work because it initializes collision checks right away.
    You should be able to set your tool length off manually without using the Tool Eye and Tool Data should accept it. Then in EIA, I would expect if you shut off the interference check buttons and perhaps turn on Barrier Cancel, it should run.
    Throwing rocks at a wall here....
    It's just a part..... cutter still goes round and round....
    Feb 2007
    198
    SU 110 to SU 113 are new parameters for "not to exceed" tool lengths.
    Whether or not these new parameters are used is up to
    SU154.1, on/off bit parameter.
    Double check with your MAZAK people and always be careful when changing parameters. The above parameters should take effect 'instantly', instead of reboot.
    -jim
    Jan 2005
    49
    Thank you for your help, we have contacted Mazak and is waiting for their reply.
    May 2010
    5
    Re: tool length to long
    Thank you Jim. turning off in 154.1 worked
    Dec 2008
    3109
    I would say that that feature is to stop you putting a tool through the chuck wall while using another tool
    - ie a long drill in station 8 when using a back turning tool in station 3
    To keep the parameter active, try removing unused tools (and adjust Z lengths) so the difference in Z length offsets is less (or don't use those short offset tools)
  1. Looking for long length reamer
    By ranchak in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 08-14-2017, 05:34 PM
  2. Replies: 7
    Last Post: 01-23-2013, 05:46 PM
  3. Long length engraving bits / needle
    By Loonie1989 in forum CNC Tooling
    Last Post: 11-16-2012, 09:40 AM
  4. accurate length on long parts - methods?
    By pmurdock in forum Haas Lathes
    Last Post: 06-16-2012, 09:43 PM
  5. Need Extra Long Ball End Mills (12"overall length)
    By CADkathy in forum Toolgrinding / Toolgrinding Machines
    Last Post: 02-18-2005, 04:54 AM
