530,019 active members*
2,899 visitors online*
Results 1 to 5 of 5
    Apr 2019
    8
    Tool offset troubles
    hi to everybody,
    my goal is to use KmotionCNC for lathe control and I realized how confused my knowledge on the Tool Offset issue is. Therefore:
    The offset value of each tool to which zero is it referred? Machine zero? If so, I have another problem: my lathe is completely self-built so there is no "Machine Zero pre assigned by the manufacturer" and I don't have a well defined point whose coordinates I know with respect to Machine Zero. Can it be in any position of the lathe axes?
    In the KmotionCNC ToolFile, at the offset columns, I note that only the X and Y axes are present while I should set X and Z: should the "Length" column be used for the Z offset?
    thanks
    Apr 2019
    8
    Re: Tool offset troubles
    Tom please can you at least give me the answer regarding the KmotionCNC ToolTable
    thanks
    Junior Member
    May 2006
    3519
    Hi geppo_it,
    GCode offsets are complicated and a number of approaches can be used.
    You can probably use any reference as long as it is consistent.
    It also depends on your requirements and work flow. Do you expect to change tools and not "touch off" the tool?
    You might read through this Thread.
    TK
    http://dynomotion.com
    Apr 2019
    8
    Hi Tom
    I will read that thread carefully. What about the Z offset? Do I have to write it on "Length" column as for a mill?
    Junior Member
    May 2006
    3519
    Hi geppo_it,
    yes
    TK
  1. Replies: 8
    Last Post: 09-17-2015, 04:14 AM
  2. Tool offset with work offset
    By botha.y in forum SIEMENS Sinumerik CNC controls
    Last Post: 06-04-2012, 06:31 PM
  3. Tool offset with work offset
    Last Post: 05-28-2012, 09:52 PM
  4. Troubles with 2012 tool tables
    By glovebox20 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-02-2012, 02:08 AM
  5. mori seiki al2 w/yasnak L3 work offset troubles
    By mkshrews in forum Mori Seiki lathes
    Last Post: 11-09-2010, 08:44 PM
