505,875 active members
2,884 visitors online
Results 1 to 4 of 4
    Junior Member
    Feb 2013
    659
    Top of part value in PP?
    I've tried part_height but that just yields zero all the time, I know that reference_plane is equal to Top of Part + Rapid Plane, I can live with a set Rapid Plane value if a hard coded subtraction can then be done in the PP to yield Top of Part, but none of my guesses at syntax have worked.
    Any ideas gents?
    TIA,
    Nick
    Junior Member
    Feb 2013
    659
    Re: Top of part value in PP?
    I've sorted out Advanced Posting for BCC V25 through to V29 so I'm just adding a tab to the drilling wizard with an input box allowing me to pass Top of Part directly to the VbScript in the PP
    No posers
    Apr 2008
    1574
    I was digging around today in the documentation for V31 and stumbled upon this API call today.
    MILL_Get_TopOfPart() – API Only
    Mill Job
    Returns the top of feature value for the current feature.
    I haven't tried it but it looks promising. Trouble is I don't know what version this API call is valid for. But thought it was worth mentioning!
    Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
    Junior Member
    Feb 2013
    659
    Thanks for that!
    I'll see what that yields in V25 when I next delve into the PP
    Regards,
    Nick
  1. Replies: 0
    Last Post: 01-18-2019, 03:21 PM
  2. Replies: 2
    Last Post: 02-28-2016, 10:07 AM
  3. Replies: 1
    Last Post: 05-17-2015, 08:37 PM
  4. RFQ for part to mount on picatinny rail and sheetmetal part
    By JAW in forum RFQ (Request for Quote)
    Last Post: 08-23-2012, 02:00 PM
  5. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 07:18 AM
