1. The A axis can automatically rotate 0-90°, while the C axis can rotate up to 360°.
2. The slab can be positioned by taking photos. In addition, this machine can automatically plan the cutting path directly from the generated map, greatly improving processing efficiency.
3. The overturned worktable is adopted, which has large overturning weight redundancy, up to 85°.
4. The Italian servo motor is used to complete circular cutting, square cutting, fan cutting, oval cutting, 45 bevel cutting, drilling, outer edge polishing, etc.
