554,066 active members*
3,718 visitors online*
Results 1 to 6 of 6
    *Registered User*
    Jan 2016
    96
    Tormach battery need
    My 1100 is old enough that it came with mach and I upgraded to PathPilot. I read about cnc machines loosing their parameters when a maintenance battery dies. Do these machines have one either in the controller or the cpu?
    My machine is unplugged a lot, especially due to lightning storms.
    Thanks Dave
    Apr 2020
    3
    Re: Tormach battery need
    Yes, there is a coin cell in the controller which needs to be replaced every few years. I think Tormach has a bulletin on it but it is pretty straightforward. Open the case and find the silver coin cell and replace. You will likely have to go into the bios to reset the clock but it should boot properly with a new battery, whose purpose btw is to retain the settings in memory. Good luck.
    Apr 2020
    3
    The coin cell I mentioned in my prior post is in the cpu case on the motherboard.
    Nov 2013
    398
    Yes, the coin battery in the CPU does need to be replaced.
    And it's not easy to access either!
    I got so frustrated trying to get to mine, that I took it into a computer repair shop, and let them do it for me.
    Dec 2013
    5598
    Quote Originally Posted by toyshop View Post
    Thanks Dave
    Not in the same sense as a Fanuc system might lose parameters. Any PC based system like the Tormach has the parameters stored on the hard drive, as a file, so you won't lose the parameters on a BIOS battery fail. A hard drive failure would cause a loss of parameters, so back up your hard drive. Hard drives fail, it is not a matter of ''if'' it's a matter of ''when''.
    Jim Dawson
    Sandy, Oregon, USA
    *Registered User*
    Jan 2016
    96
    thanks, Dave
  1. 2100 NCK ALARM 810D - NEED TO CHANGE BATTERY - WHERE IS THE BATTERY LOCATED?
    By scottbryce in forum SIEMENS Sinumerik CNC controls
    Last Post: 09-22-2021, 07:35 AM
  2. Best quality lithium carbonate battery grade supplier and battery grade dealer
    By elitechbio in forum Uncategorised CAM Discussion
    Last Post: 12-12-2018, 09:12 AM
  3. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  4. Replies: 2
    Last Post: 11-07-2013, 04:34 AM
  5. Battery Backup (UPS) for the Tormach computer
    By LRF in forum Tormach Personal CNC Mill
    Last Post: 05-11-2013, 09:22 PM
