530,080 active members*
2,544 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach TTS toolholder library for Fusion 360
Results 1 to 7 of 7
    Mar 2020
    85
    I'm not sure if anyone else has done this but my searches have turned up empty. Many of you may have noticed that along with the new tool library in Fusion 360, all the previously built in tormach tool holders are gone. Not to mention the list was somewhat incomplete anyway. I wasn't overly concerned about it until recently due to an embarrassing number of crashes that could have all been prevented if I had tool holders selected when simulating my tool paths. I finally decided to eat the time and make a new library for myself. I have attached said library here in case anyone else has need of it. Included are the 1/4 and 3/8 set screw, er20 and 32 collet, slitting saw arbor, 1/4, 3/8, and 1/2" keyed chucks with JT taper bases, tension/compression head with generic quick change chuck installed, and a super generic tts base that can be used for things like a superfly or shearhog. These are a bit simplified but should all be accurate to within a couple thou anywhere it matters.
    Attached Files Attached Files
    Jul 2011
    279
    Re: Tormach TTS toolholder library for Fusion 360
    You need to import the library back into fusion 360.
    Directions here.
    https://knowledge.autodesk.com/suppo...usion-360.html
    Mar 2020
    85
    If you're referring to the sample tormach libraries listed for 1100 and 440/770 starter, those do seem to contain the tool holders that used to be available directly in fusion (knowing that would have saved me some time) but only the 1/2 and 3/8 set screw, jt1 drill, and er20 collet holders. I've added the two larger drill chucks, the er32 collet, the 1/4" set screw, the tension/compression quick change tapping head, a somewhat generic 1" slitting saw arbor, and a general purpose TTS base for use in creating any additional custom tooling.
    Jul 2011
    279
    Quote Originally Posted by soofle616 View Post
    I see what you mean. Its a bit sparse. I did not really use the original Tormach tool library so I was not sure how much was in it. I do use the TTS but not on a Tormach. Someone out there must have a more complete library to download.
    Mar 2020
    85
    Quote Originally Posted by upnorth View Post
    Someone does. It's attached to the first post
    Jul 2011
    279
    Ok there it is! I tend to go in here first think in the morning before I have had my first coffee. I'll download it and have a look.
    Mar 2019
    6
    Thanks! Nice work
  1. Replies: 4
    Last Post: 06-07-2020, 04:45 AM
  2. Has anyone done 4th axis on Tormach and Fusion
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 12-05-2016, 11:04 PM
  3. Need some quick help, Fusion 360 CAM and the Tormach Lathe
    By David Bord in forum Tormach Slant Lathe
    Last Post: 03-17-2016, 05:50 PM
  4. Tool Library Tips/Tricks Fusion 360
    By tbev in forum Autodesk CAM
    Last Post: 12-18-2015, 04:11 PM
  5. Tormach Post and Fusion 360
    By grimms3 in forum Tormach Personal CNC Mill
    Last Post: 10-20-2015, 04:58 AM
