585,992 active members*
5,610 visitors online*
Thread: TorqCut 22
Results 1 to 4 of 4
    TorqCut 22
    HDD Failure also this morning. I do have the backup disk which i ran back in january of this year, but when i insert the 1st disk it says non system diskette microsoft backup diskette. i must have done something wrong for making the backup. Is there something i can do to make these disk work to recover my machine? Thanks for any help please!!
    Nov 2014
    10
    Re: TorqCut 22
    Hey Man sucks to hear that. Did you install ms dos first? I recall using the back-up command only saves a copy of the Bridgeport operating system. but don't quote me on that.
    You know what version of DX32 your machine is running? can send you my back-up, but you'll probably need to config the parameters for your machine.
    Re: TorqCut 22
    is there a thread on here that talks about cleaning up the computer end of this machine and starting fresh? Its a checksum error that occurs when the machine is fired up. i Think maybe it needs a fresh install from a backup of the machine files and dos 6.22 idk?
    Mar 2021
    Re: TorqCut 22
    I just picked up a TC22 and had a checksum error on initial boot up. It turned out to be the CMOS battery (on the motherboard) was dead. Replaced the battery, some bios setup and it’s up and running. Easy enough to check battery voltage on that CMOS battery. Should be 3.6v if I recall correctly. It was on the upper right side of my motherboard. Good luck
  1. Torqcut way oil
    By Jonp in forum Bridgeport / Hardinge Mills
    Last Post: 01-04-2016, 12:45 AM
  2. Need help with some settings on Torqcut 22
    By racingrob in forum Bridgeport / Hardinge Mills
    Last Post: 05-28-2015, 10:23 PM
  3. BPC-MC control - Torqcut TC-1G
    By nlh in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2009, 07:03 PM
  4. Torqcut 22 computer
    By gokarter in forum Bridgeport / Hardinge Mills
    Last Post: 01-20-2008, 08:21 PM
  5. TORQCUT 22
    By limey44460 in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2008, 01:15 PM
