589,272 active members*
5,392 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Torque Limit on M-spindle in a tap cycle - OSP-P200L, LT-200-MY
Results 1 to 10 of 10
    Jan 2022
    7
    Question Torque Limit on M-spindle in a tap cycle - OSP-P200L, LT-200-MY
    Hi folks,
    I'm trying to learn more Okuma features and have read and heard talk about using the torque limit/skip function during a M-tool tap cycle.
    I've been told it's possible to monitor spindle torque and stop and reverse the spindle/tap if a limit is reached.
    My programming manual only seems to discuss this feature during part transfer.
    Am I making things up here, or just missing the correct information?
    Any help is appreciated.
    Cheers
    Jan 2022
    7
    Re: Torque Limit on M-spindle in a tap cycle - OSP-P200L, LT-200-MY
    UPDATE:
    Looks like it's not available on the OSP-P200L machine. There is a distinct page for tap torque monitoring on our LB3000 EXII with the OSP-P300L NC.
    Jun 2015
    4172
    hello retract on load is possible, but i am not sure if it works on tapping; i will do some tests, and be back to you
    please, will you provide a screenshot from the manual, where you find that infos ? kindly
    Jun 2015
    4172
    i just find the parameter page, as attached; please, share if you found something else
    unfortunately, so far, i have never seen a discusion about those; i will try to look into, maybe i can find something / kindly
    Jan 2022
    7
    Yeah, i found the same page on our LB3000 with the OSP-P300L control, but that parameter page is not present on the LT-200 with OSP-P200L control. Perhaps an option we do not have or not available on the P200L.
    Jun 2015
    4172
    hy nyeoJSF, if you would peck, in-out like when drilling, won't this solve for your setup ?
    i started looking into your request, i hope i will find something / kindly
    Jun 2015
    4172
    hello nyeoJSF i just solved for M-spindle Torque Limit, with real tests on lathe for tapping g-codes; retract occured on overload, so all fine here
    please check your private message, on industry arena, as attached / kindly
    Aug 2011
    430
    Maybe M978 command solves this problem.
    "Imagination is more important than knowledge."
    Jan 2022
    7
    Thanks all for the feedback. It seems none of these options are available or included on the OSP-200L machine I run. Load monitor will have to suffice.
    Jun 2015
    4172
    hy nyeoJSF torque limit is an old options pack, available on p200
    please check your private message on industry arena / kindly
  1. OSP-P200L
    By sadon in forum Okuma
    Last Post: 04-13-2023, 01:44 PM
  2. Optional Parameter OSP-P200L
    By yellow75 in forum Okuma
    Last Post: 08-10-2021, 06:49 PM
  3. Okuma OSP-P200L
    Last Post: 08-12-2017, 07:48 PM
  4. tool in magazine ? osp p200l
    By filho in forum Okuma
    Last Post: 11-15-2016, 10:58 AM
  5. OSP-P200L-R / OSP-P200LA-R
    By camunderdog in forum Okuma
    Last Post: 02-03-2013, 05:31 PM
