548,600 active members*
2,566 visitors online*
Thread: Touch Probe
Results 1 to 15 of 15
    Jun 2007
    78
    Touch Probe
    I've just taken delivery of a touch probe from this chap :-
    http://www.machsupport.com/forum/ind...ic,5004.0.html
    My knowledge of lektronix extends to red cable is + (usually) !
    Can anyone who's fitted one or similar give an indepth method of connecting it before I let the smoke out???
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    23797
    What about the PDF installation instructions he mentions?
    Al.
    Albert E.
    Gold Member
    Feb 2007
    4554
    Post
    The white wire is common, the red connects to your probe input pin.
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jun 2007
    78
    Quote Originally Posted by Al_The_Man View Post
    Al.
    You mean this . . .
    Attached Files Attached Files
    Gold Member
    Feb 2007
    4554
    Post
    3.5mm wiring.
    Dec 2003
    23797
    I guess it comes with the miniature phono jack?
    The circuit just shows a string of N.C. contacts so the correct polarity is only required for the LED to operate when the probe has touched off, you can't really screw anything up as if you had the wire pair crossed it would just mean the LED would not light.
    Al.
    Albert E.
    Jul 2006
    734
    Oooh!
    Gotta get me one of those
    Jun 2007
    78
    Ok, now I know what the wires are . . . where do I put them???
    This is the bit where the smoke comes out !
    I've read that they need to connect to pin 11 of the parrallel port ?
    How, What, Why, When, Where ?
    Aug 2003
    327
    This thread should help. Have a read and post back if still unsure
    http://www.cnczone.com/forums/showthread.php?t=84671
    /M
    Jun 2007
    78
    I really am a numpty when it comes to lektronix
    Is Board 1.jpg what I'm plugging into?
    Now the hard bit, I have 3 wires from the probe, Red, White & a naked shield Cable 1.jpg, will all 3 be used? What do I need to connect to the plug - Plug 1.jpg?
    Attached Thumbnails Attached Thumbnails Board 1.jpg   Plug 1.jpg   Plug 2.jpg   Cable 1.jpg
    Dec 2003
    23797
    Pin 2-red & 3-white.
    Take the shield to ground.
    Your plug has only two active pins so if you have to find a ground for the shield.
    As long as the socket you show has the same pin out as the second JPG.
    Al.
    Albert E.
    Jun 2007
    78
    I thank you all, I really am a complete numpty when it comes to lektronics.
    Having read through the posts I salvaged a suitable connector from an old PC fan & sanded it down to fit, the problem of how to connect such tiny & intricate wires was solved by junking the supplied female jack connector & purchasing a replacement from Maplins where the wires could be soldered directly to the jack.
    Plugged it in & fired her up, touching the probe illuminates the probes LED & the 'digitise' LED lights in Mach3's diag window. And no smoke !
    Eureka, after a bit of experimentation with the Mach3 digitise wizard I've set it off on probing a complex part I've been wanting to copy for ages.
    Although this probe is going to save me lots of money it's also going to cost me a lot too, it's going to take about 3 days to create a point cloud on this part so I'm looking to buy/build a simple 3 axis machine pureley for probing.
    Sep 2015
    14
    Re: Touch Probe
    Hi All
    Does anyone know the "Magic Sauce" that Cliff uses in his ITTP probe.
    It's the contact preservative on the contacts.
    I want to try it on my Centroid probe to help keep the contacts
    in shape. Now I clean them with Acetone and then apply
    CRAMOLIN. Any ideas appreciated.
    Jun 2021
    23
    Re: Touch Probe
    He mentioned - do not remember the source (video, blog, online manual,...?) - that it is a proprietary formula he developed and does not plan to share, at least at this time.
    Sep 2015
    14
    Re: Touch Probe
    I have a friend at NASA. I'll find something.
  1. 3D touch probe
    By bschwand in forum General MetalWork Discussion
    Last Post: 12-26-2013, 10:06 PM
  2. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  3. Touch probe
    By kolias in forum Mach Software (ArtSoft software)
    Last Post: 09-08-2012, 11:16 PM
  4. touch probe
    By mick.w in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2011, 06:45 PM
  5. How to add Touch Probe
    By Wingnuts in forum Taig Mills / Lathes
    Last Post: 11-09-2010, 05:36 PM
