586,961 active members*
2,860 visitors online*
Results 1 to 12 of 12
    Jul 2016
    6
    Question Tree Journeyman 300 DC spindle drive??
    Hello all,
    I have an older Journeyman 300 that I am trying to figure out if I am able to use the Existing Spindle drive with MACH 3 or do I have to get a different drive does anyone have any ideas for running DC spindles?
    Dec 2013
    5714
    Re: Tree Journeyman 300 DC spindle drive??
    Can you post a picture and model number of your drive?
    Normally they take either 0-10VDC or +/- 10VDC command signal. With the correct breakout board, 0 - 10VDC is easily available for Mach3.
    Or use something like this for step & direction control. https://www.automationtechnologiesin...er-dg4s-016035
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    24223
    That motor shows a Tach, is this one of the old voltage feedback drives?
    These were generally as Jim says, +/-10v analogue input.
    I see this is posted in the Kmotion/Kanalog forum, are you using this type of controller?
    Albert E.
    Jul 2016
    6
    Quote Originally Posted by Al_The_Man View Post
    I was going to use a smooth stepper. I can get a picture of the drive shortly but their are a lot of inputs that I’ll have to figure out how to get it to function. This machine I would say is from the 80’s.
    Jul 2016
    6
    Quote Originally Posted by brq5008 View Post
    Hello all,
    Would a gecko drive work for this application?
    Dec 2013
    5714
    The Gecko 320X drive is only 80 volts max input, your motor is 140V. So would most likely not be a good fit in spindle application.
    This drive is 160V max input and would be a better choice. https://www.automationtechnologiesin...er-dg4s-016035
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    1573
    ...Westamp 5810?
    Dec 2003
    24223
    Modern DC drives do not use the tach feedback, I usually removed the tach brushes to avoid any future problems etc.
    Albert E.
    Jul 2016
    6
    So a motion controller would work to drive this motor than? I assume the smooth stepper should be able to run the drive with Mach 3. I could possible use the DG4s to drive the DC servos for the axis as well?
    Dec 2013
    5714
    Assuming that the axis drives are within the voltage and current rating of the DG4 drives, then they should work fine.
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2013
    77
    I have dc4 drives.. works verry good at 180v.. you just need to instal a encoder to that motor.
    Sent from my SM-G7810 using Tapatalk
    Jul 2016
    6
    Hello All,
    Starting to get back into this project and was wondering if anyone is running a DC spindle of this era and what drive are you using (VFD) to control it. I am finding selecting a drive for the motor name plate in this form rather hard to source. If anyone can please direct me in a drive that will work for this motor that would be greatly appreciated!
    - - - Updated - - -
    Hello All,
  1. Tree Journeyman 325 - SD1525-10 Drive (Z-Axis) Getting OT/RMS Light
    By PeterTheWolf in forum Servo Motors / Drives
    Last Post: 04-23-2020, 02:51 PM
  2. Replies: 28
    Last Post: 10-31-2013, 04:30 AM
  3. Replies: 5
    Last Post: 04-08-2012, 09:11 PM
  4. Tree Journeyman 300
    By hjl4 in forum Tree
    Last Post: 08-21-2011, 06:18 AM
  5. Tree Journeyman 320 Spindle Taper. . .
    By 3wheelsforever in forum Tree
    Last Post: 04-04-2007, 08:26 PM
