594,889 active members*
5,711 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Triggering Distance Help Inductive Proximity Switch NPN
    May 2011
    109
    Question Triggering Distance Help Inductive Proximity Switch NPN
    Long story but I am redoing my homing and limit switching on my large format CNC.
    I would like to make it so I can have these sensors https://tinyurl.com/yc6k8bwp move straight into their stops/triggers instead of sliding over the tops of their triggers. That way I can adjust them in or out instead of slotted mounts side to side. They also will be better protected since they are kind of long.
    On my X axis I was hoping to have the limit and home side by side with different distances to trigger them.
    I designed and 3D printed some mockups
    Attachment 510514
Name:	2024-11-29 10.27.16.jpg
    https://photos.app.goo.gl/qfwzAgjoLG25ny6A8 https://photos.app.goo.gl/fuVkicDSBw1UhrS4A
    What I was thinking is have the home sensor triggered by something stronger a few millimeters from the limit switch. Maybe have the home a piece of steel and the limit a piece of aluminum? Or would a small magnet make it trigger sooner giving me more room?
    May 2011
    109
    Re: Triggering Distance Help Inductive Proximity Switch NPN
    Well, as a follow up, I guess this was a stupid question since I’m using CNC 12 and an acorn six control board. I started my CNC journey using Mach 3, and then Mach 4 and had optical slot sensors. When those were tripped for limit switches, it immediately stopped servos and steppers where they were there was no over travel. It just stopped. Now I’m finding with CNC 12 and the centroid board that unless I’m going at one X jogging anything faster things keep moving past and will crash into the sensor it’s kind of like there’s a slow shut down instead of an instantaneous one. So now I’m reconfiguring everything to pass over the triggers.
  1. NPN Proximity Switch Wiring
    By kolias in forum CNC Machine Related Electronics
    Last Post: 03-02-2024, 01:43 AM
  2. NPN Proximity Switch Extension Cable
    By Sterob in forum Australia, New Zealand Club House
    Last Post: 05-13-2019, 01:14 PM
  3. Wiring of npn inductive proximity switches.
    By wackocrash5150 in forum DIY CNC Router Table Machines
    Last Post: 01-17-2019, 11:49 PM
  4. NPN home proximity switch
    By Upnorth4 in forum Mach Software (ArtSoft software)
    Last Post: 08-20-2018, 12:14 PM
  5. NPN Proximity Switch
    Last Post: 08-05-2016, 07:04 PM
