585,992 active members*
5,178 visitors online*
Results 1 to 1 of 1
    Jul 2020
    3
    Question TRUMATIC L3030 - 3000W - problem with PLC - inquiry
    we have a trumpf machine L3030 - 3000W. I reset the Siemens 840D according to the manuals and instructions. He played from the NCK machine and then the PLC.
    I refurbished one faulty servo. Restored the system from backup - functional.
    The laser writes the following two errors after approaching:
    1.)
    F29.03.21 12:56:30 PLC (80.102000): The machine dautm 15101 is not defined
    2.)
    29.03.21 12:52:05 PLC (07.000000): Feed pot is situated at 0
    When connected to the 840D, I see everything OK, both the memory and all the modules and the system time fit.
    It does not make any sense.
    Does anyone have this laser PLC and NCK data? I have several versions and the error is the same.
    Isn't it possible that some memory has gone?
    Thank you.
