541,034 active members*
3,834 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Trumpf Trumatic 180w WITH FANUC 6M
Results 1 to 5 of 5
    Jul 2019
    3
    Hello,
    We have a punching trumpf trumatic 180w Rotation with fanuc 6M .
    We have the problem that it doesn't put in the head the upper and the lower tool and we can not do the set up of the machine to start working.
    We have checked all the sensors and they all work properly and finally we come up that there must be a problem from the i/o boards of the Fanuc system.
    Can anyone help me please?
    Oct 2014
    129
    Re: Trumpf Trumatic 180w WITH FANUC 6M
    Have you Ladder diagram manual? This manual contains all I/O signals addresses and logic of their processing.
    If press sub-mode key [DIAGN] and enterring address of sensor signal possible to check the their bit status in Connection Unit.
    Jul 2019
    3
    Yes we have a ladder diagram manual.
    We found that address 12.0 that open and closes an air valve it should be open(have power), it doesn't have power and it is closed.
    We track it back and it goes to the i/o boards.
    We do not know what to do next.
    Hello Dears
    I have Trumpf 180, and I need any related electrical documentation, and the power supply MS140 card has a problem if you have schematic diagram or blocks diagram thanks
    Apr 2006
    92
    Quote Originally Posted by PANSOLAR View Post
    You replace IO board
  1. Trumpf Trumatic 180w
    By PANSOLAR in forum Fanuc
    Last Post: 07-12-2019, 04:23 PM
  2. Trumpf Trumatic TC-240
    By encoder909 in forum Uncategorised MetalWorking Machines
    Last Post: 03-01-2019, 10:35 AM
  3. trumpf trumatic 240
    By moez1234 in forum Uncategorised MetalWorking Machines
    Last Post: 08-29-2017, 04:40 PM
  4. Trumpf Trumatic 180
    By atanasii in forum DNC Problems and Solutions
    Last Post: 08-22-2014, 07:57 AM
