548,599 active members*
1,814 visitors online*
Thread: Twist
    Twist
    Hi Guys. I am trying to extrude a screw twist. Can someone give me any pointers please.
    Ghost
    Dec 2008
    4514
    Re: Twist
    In BobCad, you'll have to generate the upper and lower "spirals" and also the root spiral, then use a skin command...
    Manually building it. there wont be a "sweep profile" command to spit that out in 1 go...
    Ghost
    Dec 2008
    4514
    Re: Twist
    Sorry, my bad. That was for "Bolt threads".
    For a "Screw", much simpler.
    Make a helix of ypour screw. Put a single straight line down the middle of the helix center. "Cross section" the helix and the pole.
  1. Y Gantry Twist
    By OneWound in forum DIY CNC Router Table Machines
    Last Post: 09-26-2017, 07:28 AM
  2. Sweep Twist
    By RAF. in forum BobCad-Cam
    Last Post: 09-12-2015, 03:09 AM
  3. twist drill calculations
    By awjareme in forum General MetalWork Discussion
    Last Post: 06-07-2011, 11:31 PM
  4. Old Question - New Twist
    By CNC_Tools in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 04-27-2011, 08:52 PM
  5. New Twist on Wire Management
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 04-30-2003, 09:34 PM
