532,026 active members*
4,094 visitors online*
Results 1 to 14 of 14
    Dec 2016
    5
    TX14207 SCHEMATIC
    Does anyone have a schematic or image that shows or identifies each wiring connection and pin settings for a TX14207 stepper driver?
    Mine has no connectors labeled (ie I do not know which is A+, A-, B+, B-, DC+, ... etc)
    I have attached an image that has been previously posted.
    Norman
    May 2017
    20
    Re: TX14207 SCHEMATIC
    Hi Norman,
    I had to piece this guy appart a few months ago and wrote down the board schematics. I can send you what I have but it has not been curated at all.
    I found your post trying to figure out what the dip switch do... The X, Y, Z axis have 3,4,5,7 ON; The A axis has 3,4 ON.
    From left to right on the Green 6 screw terminal you have: A-, A+, B-, B+, V+, GND these connect to your stepper and power supply
    The white terminal connects to the through hole labelled ENA, 5V, DIR, 5V, P, 5V and go to the parallel card adapter.
    http://www.cnczone.com/forums/attach...d=368782&stc=1
    Dec 2016
    5
    Sincere thank you for this information - can now finish setup
    Norman
    Aug 2017
    3
    I also have this TX14207 stepper driver in my 6040 cnc router. The A-axis motor is getting hot just sitting idle so I wanted to try turning down the current but don't know the DIP switches.
    Anyone know how the 7 dip switches are setup?
    May 2017
    20
    Yeah mine is running hot too but it's meant to be like that for holding torque. If you reduce that current you will end up with the axis skipping.
    From my research, unless you can burn yourself on it, it's just fine.
    S1: M1
    S2: M2
    S3: DCY1
    S4: DCY2
    S5: TQ1
    S6: TQ2
    S7: connected to a GAL microcontroller... Not sure yet
    Sent from my Nexus 5X using Tapatalk
    Aug 2017
    3
    Thank you chronomill!
    I'll probably leave it alone then.
    Other quirk is that the 4-axis motor has jitter at idle, but only sometimes. Turn it some and it's steady. Turn is some more and it might exhibit this jitter.
    I got the seller to send a new motor and it has the same problem so now I'm thinking the motor driver is bad (TX14207 which uses a TB6560)?
    The other 3 axes do not have this jitter problem (lucky me I guess).
    Thanks,
    Rob
    May 2017
    20
    Quote Originally Posted by n4spd View Post
    Thanks,
    Rob
    Not sure what you mean by jitter, I'm not very good in English...
    Mine will find its position very accurately but will stop at a different position (reproducibly) depending on the direction from which it got there...
    Aug 2017
    3
    Let me clarify this "jitter" on the 4th axis:
    1) the motor is in idle state
    2) but the motor has a very slight movement/rotation left and right around the center/stopped position.
    Again, it's doesn't always do this, and when it does, it's a slight vibration around the stopped position.
    From my searching, this might be due to the micro-stepping when the motor is mid step but I'm not sure. My concern is that the stepper motor controller is bad.
    Thanks,
    Rob
    Oct 2017
    Heloo.does anyone knows where to bay driver TX14207 or repleacment for him.thanks
    Jul 2017
    5
    Quote Originally Posted by chronomill View Post
    S1: M1
    S2: M2
    S3: DCY1
    S4: DCY2
    S5: TQ1
    S6: TQ2
    Adding:
    S7: This reduces the motor current at low speeds i.e. less than about 10 whole steps per second. Makes the motor a run bit nosier but is kinder to the motor, the driver and the power supply.
    Oct 2017
    Does anyone know where I can purchase a TX14207 stepper driver card? I can find them anywhere??
    Jul 2017
    5
    Quote Originally Posted by jsm13266 View Post
    I think have three that I've retired if you want. You can contact me via http://bmamps.com.
    -CS
    Oct 2017
    Quote Originally Posted by CScotty View Post
    -CS
    I contacted you through your contact us on http://bmamps.com
    Nov 2020
    I search the schematic or board of TX14207 (CNC motor driver board of my CNC3040).
    Could you help me please ?
    Best Regard,
    Claude.
  1. MDX 40 Schematic
    By richard_ in forum Want To Buy...Need help!
    Last Post: 11-20-2015, 09:32 AM
  2. CRM schematic
    By Skiroy in forum General CNC Machine Related Electronics
    Last Post: 03-11-2012, 05:58 AM
  3. From schematic to PCB?!
    By jhovel in forum General CNC Machine Related Electronics
    Last Post: 05-28-2011, 02:24 PM
  4. Schematic Available?
    By Don Peterson in forum Hobbycnc (Products)
    Last Post: 04-16-2009, 03:31 PM
  5. THC Schematic
    By Bostjan M. in forum General Waterjet
    Last Post: 06-22-2008, 01:35 PM
