586,005 active members*
5,130 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > UC300 ETH stepper drive connections
Page 1 of 3 123
Results 1 to 20 of 48
    May 2011
    37
    The UC300 is designed for use with breakout boards, and you shouldn't be wiring your drives directly to the UC300 motherboard.. Those 5 ports are for plugging breakout boards into them.
    Many people find that the $5 boards work very good.
    Hi Gerry,
    I'm a newbie about cnc controller , I have buy a UC300ETH, but I have a dubt also the manual installation of CNCdrive not more clear about. I need use UC300 with my four drivers by china type DM542 and 4 motors nema 23 for a 4 axis mill. Can you explain also with drawing schematic , how to make a system that work fine ? I need of buy also breackout card for each axis for conect my drivers ? what type of breackout I need andwhere must they be connected on uc300 output connector pins ?
    Whitch can be a right configuration with my drivers and motors?
    thanks
    Mar 2003
    35538
    Re: ES-DH2306 Drive with UC300ETH Motion Control Board
    Any breakount board will work, even one of these cheap ones. All 4 motors drives connect to it.
    5-Axis CNC Interface Adapter Breakout Board For Stepper Motor Driver Mach3 USB
    Just plug the cable into port 2 or 3 on the UC300 motherboard. Here's how to wire it.
    https://www.machsupport.com/forum/in...html#msg199107
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2011
    37
    I again confused, I need connect uc300eth with other card breakout parallel 5-Axis CNC Interface Adapter Breakout Board For Stepper Motor Driver Mach3 USB | eBay , but I have buy already a card controller ethernet type.
    For use my driver dm542 i need link them with your breakout parallel and then with uc300 ?? The drivers cannot work if wired with uc300 direct ?
    Mar 2003
    35538
    The parallel connection plugs into the UC300 motherboard.
    Gerry
    May 2011
    37
    I have understand this
    this is right ?
    Apr 2013
    1899
    Yes and no. Yes, this is the way to connect it but no, not the right port. Connect it to the next one, which is port 2.
    Mar 2003
    35538
    Re: UC300 ETH stepper drive connections
    Here's how I have mine setup right now, using port #2.
    Gerry
    Sep 2005
    1195
    Gerry,
    Can we use that UC300ETH and the BOB with servo driver such as G320X and servo motor from Keling...?
    Apr 2004
    733
    Quote Originally Posted by asuratman View Post
    Gerry,
    I'm running a UC300eth with the same BOB. Gecko320x with minertia servo motors on the Y and Z axis. Dual Gecko202 and 280oz-in steppers on the X axis. No problems.
    Sep 2005
    1195
    Jfong,
    Thanks for the info. I plan to do it for my next project...
    May 2011
    37
    thanks Gerry ,,
    now I have received the card her is here,
    I had try for install on my pc, but have a problem for recognize on system OS. I have connect it with cable lan rj45 to port pc lan , but not run . The card flashlight led green , and also port back pc lan flashlight little time, card not recognized.
    In manual user showed the config with router also with cable crossover modded, but also non work on my router. Can help me ?
    Mar 2003
    35538
    The manual explains exactly how to do it. http://cncdrive.com/MC/UC300ETH%20da...ETH_manual.pdf
    Don't use the router.
    Set up the network as shown on pages 8 and 9 in the manual, and plug the UC300 directly into the PC. If you start UCCNC and don't get a blue light, then you may need a crossover cable.
    I added a second network card to my PC, and plug the UC300 directly into that.
    Intel EXPI9301CTBLK 10/100/1000Mbps PCIe Network Adapter Card | eBay
    Gerry
    Apr 2013
    1899
    Works just fine through a router as well but you need to know how to set it up since the manual is not that well written. It is overcomplicating it in my opinion.
    May 2011
    37
    I have checked the cable it crimped bad, now the card is recognized but unknown ethernet card, not signed name UC300eth, I have set same descibed on manual . This is very strange, I hope that the card not broken.
    A_camera can you place the instructions right for config router setup?
    Apr 2013
    1899
    Quote Originally Posted by walkit View Post
    Start with a factory reset and see if the utility software recognise the UC300ETH. I think you should follow the instructions in the manual. Every word of it. You must be familiar with setting up network connections otherwise it will be difficult. I have very little time to assist you step by step. If you are not familiar with LAN configuration it will be too difficult for me to assist you. Try to find someone who speaks Italian. The UC300ETH is pretty easy to set up but you must have some basic knowledge to start with and I don't have the time to give you that. Sorry.
    Apr 2013
    1899
    Please read the manual. Page 6 seems to explain the situation and what to do:
    Please note that the network on the above printsceen is already renamed to UC300ETH. By default the network will have a name localconnection or similar. To rename the connection click the change adapter settings on the left side of the window.
    In Italian:
    Si prega di notare che la rete sui printsceen di cui sopra è già rinominato UC300ETH. Per impostazione predefinita, la rete avrà un LocalConnection nome o simile. Per rinominare il collegamento cliccare le impostazioni della scheda cambiamento sul lato sinistro della finestra.
  17. #17
    May 2011
    37
    Thanks again Gerry , I have a different breakout card :
    Attachment 347026
    I need of power supply +5V each cards ? UC300ETH and Breakout board ? Can you explain how to wire this cards ...
  18. #18
    Sep 2005
    1195
    Hello Gerry and A_Camera,
    I read on their manual, it works only with windows XP, it doesn't work with windows 7 64 bits. Which MS Windows run your system CNC BOB with ? If using ethernet cable on UCC300ETH, since the notebook maybe too far from the BOB, can we use external switching PS 5VDC connect to BOB's USB ?
  19. #19
    Sep 2005
    1195
    Hi Walkit,
    I purchase Wantai with the same BOB as you show it #17, but I plan to purchase also 5-Axis CNC Interface Adapter Breakout Board For Stepper Motor Driver Mach3 USB | eBay. Since it is cheap and it works as people said here.
  20. #20
    Apr 2013
    1899
    Attachment 347026
    I don't know that BOB and don't know why there are two separate +5V and GND on the right side. Normally the inputs have opto isolators and those are driven with a separate supply between +12V and +24V. The UC300ETH and the BOB can share the same +5V but yes, both must be connected to +5V, however, I would not share the same +5V with the inputs since the opto isolators lose their purpose in that case.
Page 1 of 3 123
  1. aze-cc4q servo drive connections
    By ceencee in forum Servo Motors / Drives
    Last Post: 12-06-2023, 09:27 AM
  2. yaskawa drive connections to BOB. help
    By Deano7/11 in forum Servo Motors / Drives
    Last Post: 03-22-2012, 09:39 PM
  3. hel with DC motor drive connections
    By leandrot in forum CNC Machine Related Electronics
    Last Post: 06-04-2010, 08:15 PM
  4. Stepper motor connections
    By muddobber76 in forum Controller & Computer Solutions
    Last Post: 10-12-2009, 06:18 PM
  5. with a Dover air Spindle, DMM-1000 drive connections
    By DiamondGirl in forum Servo Motors / Drives
    Last Post: 02-19-2008, 02:56 AM
