554,748 active members*
2,327 visitors online*
Results 1 to 13 of 13
    Jul 2018
    3838
    UCCNC Laser plugin - how to connect?
    Hi - I use UCCNC for router work. I want run a laser from UCCNC via its laser plugin. I have a gecko G540 on one machine and a ST-6560V4 on another. Both do not have a PWM output. Is there a way to do this externally? To get this to work what controller is best? or how would this usually be done? Regards Peter
    Mar 2003
    35528
    Re: UCCNC Laser plugin - how to connect?
    What CNC Drive controller are you using?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2018
    3838
    Hi Gerry a Gecko G540 or a ST-ST-6560V4. see attached. They don't have a PWM output so I can only turn them off and on via the spindle control?? Peter
    Mar 2003
    35528
    UCCNC requires a hardware controller. UC100, UC400ETH, AXBB-E,....
    The PWM signal comes from the controller.
    Gerry
    Jul 2018
    3838
    Looking at the UC100 it has a spindle PWM output may be able to use that for the laser. But I looked at my other machine and its BOB has a PWM output so I'll remount the laser on that machine and see how I go. Reading its BOB manual now. Peter
    Mar 2003
    35528
    If you plan on using UCCNC, and don't yet have a UC100, I'd recommend a UC300ETH, UC400ETH, or AXBB-E.
    All have more powerful chips on board, support more features, and have better noise immunity than a UC100.
    And they all have more I/O, allowing both PWM spindle and laser.
    Gerry
    Jul 2018
    3838
    Hi Gerry- I have the UC100 but I'm looking at options for another machine. Will look at those. Peter
    Nov 2008
    614
    I tried to get router CAM and hardware to work on my laser for years. I found a way to do it but then bought a DSP controller and found they are far better for a number of reasons.
    Key advantage is you upload the code and go off and do something else with your computer. You can then repeat jobs at will. They are perfectly suited for lasers.
    Mar 2003
    35528
    I think he's just using a diode laser.
    Gerry
    Jul 2018
    3838
    just a 10W diode laser - Peter
    Sep 2019
    9
    i just got a AXBB-E and for the life of me i cant get it to
    work. Really no documentation on the connections required.
    I had it working with mach3 and lightburn on my old gerbl board.
    it is a 15w diod laser with pwm/ttl and uses a 12v supply
    i have hooked up the pwm lead to the pin 17 and input that into
    uccnc but stoofed if i can get it going.
    Aug 2019
    11
    Did you ever get this working?
    Nov 2008
    614
    Controllers for routers move the machine in three axis, turn the spindle on and off and control spindle speed. None of that turns a laser on and off during a vector cut. Less so in a roster cut used for an image.
    So you not only have to steal a couple outputs channels to control laser intensity and power, you also have to have software that supports a laser and three axis milling functions.
    This all exists in the open source world and in those exchangeable head machines that also have their own code.
    Solution? You need a laser then get a laser.
    Btw lasers burn wood which creates smoke. Routers are not designed to capture smoke.
  1. New MODBUSEZ SetUp Plugin For UCCNC
    By Dan911 in forum UCCNC Control Software
    Last Post: 10-19-2021, 10:20 PM
  2. PCB Autoleveler Plugin for UCCNC
    By cahit in forum UCCNC Control Software
    Last Post: 11-22-2019, 01:41 PM
  3. Plugin for UCCNC not showing up
    By SamHam in forum UCCNC Control Software
    Last Post: 04-20-2019, 04:37 PM
  4. Uccnc - plugin creation - pendant
    By robertspark in forum UCCNC Control Software
    Last Post: 09-02-2017, 09:42 AM
  5. Waiting for VistaCNC plugin for UCCNC
    By iflyinverted in forum UCCNC Control Software
    Last Post: 05-25-2016, 04:20 AM
