504,064 active members
3,084 visitors online
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > UCNCV4 usb cnc controller board with opto isolation and relays and offline functions
Results 1 to 8 of 8
    Apr 2004
    154
    The board is not bad at a glace. The MFG seems to have abandoned it. UCNCV4 http://www.variometrum.com/PDF/USBCNC_csatolo_ENG.pdf produced by https://variometrum.hu/ still has for the moment the PDF file available. I have removed the metal can from the board to expose the MAIN processor. it is a pic18lf4550-i/pt with a programing port next to it. I'll post the pinouts when I get the chance. There is a secondary processor on the board with a programming port as well. stm8s903k3t6c again I'll post the programing header when I get the chance.. Different web sites seem to claim different functions. some say usbcnc control software only otheres talk about mach3 support...... I have the CD that came with it I have yet to look at it...
    Apr 2004
    154
    Re: UCNCV4 usb cnc controller board with opto isolation and relays and offline functi
    Package include:
    1 x 4 axis USBCNC breakout board
    1 x Hand controller
    1 x USB Cable
    CD include with English user manual and software and register code.
    This is Video download address:ddcnc.com/file/usbCNCV4.rar
    1. Products brief introduction
    USBCNCV4.0 is a high performance motion controller which based on PC software USBCNC control, the system can complete the convers$
    2. Computer system requirement
    1) CPU:1GHz
    2) Memory: 512MB
    3) 500MB free disk space
    4) DIRECTX9 graphics device with WDDM 1.0 or higher driver
    5) USB 2.0 interface
    6) Net FRAMEWORK 3.5SP1
    1) CPU:2GHz
    2) Memory: 2GB;
    3) 1G free disk space
    3.Production appearance and size
    1. After the revision,V4 version using the red PCB board, PCB size is 135.3*82.5mm.;
    2. The front of the narrow edge placed with USB communication interface and DB9 hand control interface for the convenience of cus$
    3. The back-end of narrow edge is power input and output interface and 3 relay output interface; relay is strong interference sou$
    4. One of the two wide sides is stepper motor and principal axiscontrol signal output;
    5. The another side of two wide sides is the emergency stop, manual speed input, limiting input interface; one side for the input$
    6. 5V and 12V power module compact independence, security, stability;
    7. External ensure the stability of the system work effectively with crystal active and main control chip shield;
    8. The software is USBCNC,not mach3,pls note!
    4.Detailed functional introduction
    A. Card input voltage: 15~36V;
    B. Limit port working voltage: 12V;
    C. Stepper motor control signal output voltage: 5V;
    D. External power supply voltage: 12V;
    Note: marked 15~36VDC is input interface, marked 12V is output interface, can not wiring wrong.
    5.Function and definition of each module
    A) USB interface, connect to the computer USB port through this interface,you can use the software usbcnc to control this board, this USB interface is the square B interface,please use USB2.0 connection cable which with shielding and ma$
    B) Hand control box interface, external hand control box can use this interface to access the system, the interface is standard DB9 form, its definition as shown in the following table.
    C) Power indicator, as shown in figure the above D10 indicator is the front-end USB power indicator, this light lit up after USB port connection with computer , D2 in below is the back -end power indicator light, this light also will li$
    D) Board card firmware upgrade button UP and reset button RST, firmware has been updated, so upgrade button don?t need to use, reset button be used when need to restart due to the board fault.
    E) Manual speed control interface,wiring connection mode as shown in the following figure .
    F) Limit input interface. Limit interface definitions are listed in the following table in the user manual
    G) Spindle control selector switch, as shown in Figure 1-6, the switch shift up to the S1 position for the spindle speed control ; switching switch position On below for output control MIST relay .
    H) External pause and reset interface; the 2 feet marked PAUSE connect suspend switch, 2 feet marked RESET connection reset switch.
    I) Software MIST control relay output, software settings output marked 3, defined from top to bottom, 3 feet is NC, NO, COM.
    J) Software FLOOD control relay output ,output marked 2 in the software settings , defined from top to bottom, 3 feet is NC, NO, COM.
    K) Software SPINDLE control relay output , output marked 1 in the software settings , defined from top to bottom, 3 feet is NC, NO, COM.
    L) Board working power input, levels above negative below as the board signed, please pay attention to input DC 15~36V, overvoltage or reverse connection will damage the board.
    M) 12V output interface. as the board marked, GND is -, 12V is +.
    N) Spindle control output interface: definitions turn for GND DIR PWM2 12V, respectively is ground,direction signal output, spindle 0~10V speed control signal output, 12V output.
    O) A axis stepper motor control signal output, the definition is:CK+CK-DIR+DIR-,respectively is impulsion positive, impulsion negative, direction positive, direction negative, the board using common anode connection method, so CK+ and D$
    P) Z axis stepper motor control signal output, the definition is CK+CK-DIR+DIR-, respectively for pulse positive, pulse negative, direction positive , direction negative, the board using anode common connection method, so CK+ and DIR+ l$
    Q) Y axis stepper motor control signal output, the definition is CK+CK-DIR+DIR-,respectively for pulse positive, pulse negative, direction positive , direction negative, the board using anode common connection method, so CK+ and DIR+ li$
    R)X axis stepper motor control signal output, the definition is CK+CK-DIR+DIR-,respectively for pulse positive, pulse negative, direction positive , direction negative, the board using anode common connection method, so CK+ and DIR+ lin$
    Apr 2004
    154
    "The Faster CNC manual control box" the hand held controller with a DB9 connector. it is prob a matrix control I'll do more probing later but as is the inside of the box has 10 wires 9 are used. NO shielding wire.
    red 1 orange 2 purple 6 white 7 green 3 gray 8 yellow 4 blue 9 black 5 I'm not about to PEEL off the face to get a look at the membrane circuits. all details posted about the manual control box are the wires INSIDE the box going to the membrane.
    Apr 2004
    154
    Did some probing finally, the HEADER on the board for P2 5 pin header next to the DB9. from the PIN closer to the db9 goes to PGC, PGD, GROUND, VDD/PIN7, MCLR The PGC also connects to U3 opto isolator, MCLR connects to U4 opto isolator. u3 and u4 are direct TRACES to the optos from the header pins. Please let me know if this helps any one? ALSO I would assume CNCDUDEZ CODE COULD work on this board with some adjustments?
    Apr 2004
    154
    I just realized something.. The board I have is a little difference version wise then the PDF one. only one aspect is different. The upper right hand corner near the spindle control mine has the second micro controller. I'm not really sure what its function is I have not had time to probe it.....
    Apr 2004
    154
    Some great new information!!!!! the UCNCV4 is produced by https://planet-cnc.com and the ucncv4's are dirt cheap almost give away prices from aliexpress amazon and other sources. I have gotten a few of them now just buy purchasing parts and they have been tossed in as an EXTRA... So where am I going with this? every new UCNCV4 I have gotten has come with a CD and the cd has a license key on it. the software from https://planet-cnc.com recognizes the driver and updates the firmware and exceps the registration. https://planet-cnc.com now has a windows and linux versions of there software.
    Apr 2004
    154
    Got a hold of Planet-cnc tech support finally... according to planet cnc the board is a chines counterfeit. And a very well done counterfeit I might add. I did not install the software that came with it. which for me is the same with all china (crap) I dont trust the software. I am going to assume when I let the planetcnc official software update the board I likely overwrote a custom hacked firmware that had other features enabled. By default there are a number of functions that are not enabled by the FREE DIY software version (unfortunately). The knock off that I have the UCNCV4 is based on this https://planet-cnc.com/diy/ and this is based on the discontunued MK1 cnc controller. The DIY and the MK1 are the same controller minus a few features by planet-cncs design, even though its the same controller chip. After testing the board I have had no issues with it, Planetcnc's software was very easy to setup and get settings correct. In hind sight I do wish I had tested the china crap "version" of the planetcnc software if I had a disposable windows install computer setup. Sadly at this time frame of testing the laptop I would have tested has a failed rechargeable bios battery and will not post. My opinion of the board, the UCNCV4 it is a very very well designed board. it has 3 onboard 15amp relays everything is opto isolated. This board would be a very VERY good candidate to be modded for GRBL or https://www.klipper3d.org/ . klipper out preforms GRBL at a historical level for step rates.
    Apr 2004
    154
    Some more cool news, So I have finally had some time to really fully play with the software from planetcnc and the UCNCV4 board. I now have the Z tool height probe setup and working, the spindle speed control and some off sets all working with great success. I would likely describe planet cnc's software as almost plugnplay in regards to the basic level of set up needed to get the system up and running. And its not designed with a heavy learning curve right off the bat. The options ARE there for very advanced features, but the software is designed with common defaults I guess you could say. Planet CNC hardware/software. I would say worth the money. Two thums up, no pinocchios.
  1. Usefulness of the Opto-Isolation in Breakout Board
    By leaveme in forum DIY CNC Router Table Machines
    Last Post: 09-22-2010, 07:47 PM
  2. LPT Opto isolation BOB
    By shulio in forum General CNC Machine Related Electronics
    Last Post: 03-12-2009, 01:01 AM
  3. Proper Opto Isolation
    By Karl_T in forum CamSoft Products
    Last Post: 07-24-2007, 03:18 AM
  4. Opto isolation on the Gecko G320?
    By jguillen08 in forum Gecko Drives
    Last Post: 10-01-2005, 02:05 AM
  5. Parallel Port Opto Isolation ???
    By GrahamIT in forum General CNC Machine Related Electronics
    Last Post: 07-17-2004, 02:57 PM
