525,666 active members*
2,457 visitors online*
    Apr 2015
    9
    Exclamation Uneven engraving on ABS material
    I have a Chinese laser co2 60w machine. Lihuiyu controller with CorelLaser
    Everything was fine for a small period of time, and now I have a problem.
    The engraving is uneven (you can best see it on white material) There are places where it burns more material and places where less material is burned. (engraved deeper)
    I mainly engrave ABS dual layer material.
    I did some research and my guess the laser tube or power supply for the laser tube or the material
    I also checked so that the lens is not loose or moving inside the laser head.
    I attached a picture.
    Can someone tell me what is the problem. What should I replace?
    Thank you!
    Dec 2019
    22
    Re: Uneven engraving on ABS material
    unstable level of power from laser source way above 5.00% with the combination of low resolution optics/lenses 100um and above installed in the machine. Kind Regards.
    Apr 2015
    9
    Thank you for your message. Should I try and change the laser power source?
  1. Uneven engraving mystery...
    By syo in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 08-15-2016, 02:55 PM
  2. PROBLEM - Uneven engraving from left to right
    By Lunder in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 12-13-2015, 11:33 PM
  3. GADJ - Tool for Engraving Uneven Surfaces
    By jblakey in forum G-Code Programing
    Last Post: 04-24-2014, 01:04 AM
  4. Engraving and uneven surfaces
    By phatjap in forum DIY CNC Router Table Machines
    Last Post: 04-21-2010, 01:11 PM
