585,927 active members*
3,876 visitors online*
Results 1 to 6 of 6
    Nov 2014
    4
    Unimig Razorcut 45 - Machine Torch?
    I am not new to CNC having made several wood routers but am new to Plasma.
    I am currently building a Plasma CNC and need a machine torch. I am in Australia and have a Unimig Razorcut 45. The razorcut 45 is used on several machines sold here but I have not been able to work out which torch they are using.
    Any suggestions on which machine torch will fit or can be best adapted to work with the Razorcut? it uses an SC30 torch as standard.
    Dave
    Aug 2006
    225
    Re: Unimig Razorcut 45 - Machine Torch?
    Quote Originally Posted by davo453 View Post
    Dave
    Hey Dave,
    Did you find it. Im just about to start building a machine for a guy and he has the razor cut 45. Not much is documented but from what i see it looks liek the machine torch for the razor cut 80 also works on the 45? IS this correct and did you get a pinout for the connector? Finally if you have been using it how does it compare.
    Nov 2014
    4
    Quote Originally Posted by twistedfuse View Post
    Hey Dave,
    Nope yours is the first reply and as I am still waiting for other parts i've let it slide a bit. I did find out that Unimig do a "SCM80R Suregrip Series Plasma Torch" that works apparently but the dealer i approached to try and get one didn't bother to reply.
    I may just modify the existing torch
    Nov 2014
    4
    Hey Dave,
    https://unimig.com.au/product/scm80r...-plasma-torch/
    Aug 2006
    225
    Hi Dave, thanks heaps for the update. Not sure what the issue is with unimig but haven't gotten a response since I emailed them. Keen to see your setup when running I'll be I'm hoping my design will be complete by end of week then as long as customer is happy with cost and look I'll hopefully start next week procuring and fabricating
    Sent from my SM-G965F using Tapatalk
    Aug 2006
    225
    Double post removed
  1. SL 100 CNC Machine Torch / Manual Torch
    By Turbo67 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-18-2018, 03:03 AM
  2. Wanting to change my Hand Torch to a Machine Torch?...
    By winegar in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-14-2014, 09:38 PM
  3. Hand torch to machine torch
    By matttargett4 in forum Hypertherm Plasma
    Last Post: 06-01-2010, 09:37 PM
  4. hypertherm 1000 hand torch to machine torch
    By duraflap in forum Hypertherm Plasma
    Last Post: 05-18-2010, 08:34 PM
  5. Different between hand torch& machine torch
    By ltran2000 in forum Waterjet General Topics
    Last Post: 03-02-2008, 04:19 PM
