567,245 active members*
4,615 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > updates made program worse!
Results 1 to 12 of 12
    Nov 2006
    227
    Have seen quite a few issues with bobcam so far. At best it seems able to do minor profiles and drill holes.
    After installing updates (they were to fix issues...), now, drilling a hole is out due to the fact no post processor will work...
    Anyone else install updates?
    How can I get rid of the update so I can at least drill a damn hole.
    I am back to being a big fan of notepad. At least I can write programs that work!
    Mar 2012
    1565
    Jest,
    The problems people have been talking about has to do with simulation. Trust me you can a lot more than profiles and drilling holes.
    If you can't post there are a few settings you would want to check.
    1- try post and save. If you do not have your nc file path setup correctly then hitting post will not work. If post and save as will write a program then you know thatgs your problem
    2- have you selected a post that is avaliable? Maybe you are using a file that ran in an earlier version. It the software maybe looking for a post that it doesn t have access to....
    3- rare but youre virus software could be the problem.
    Anyway you can always call support and they will get you sorted out. If there is anything I can help with please let me know.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Nov 2006
    227
    too disgusted to bother with a full reply.
    Mar 2012
    1565
    jest,
    Al DePoalo
    Nov 2006
    227
    if I had been smart... Use the forum guys.
    If I had looked closer, today would have been far more productive!
    http://www.cnczone.com/forums/bobcad...ild_769_a.html
    Ghost
    Dec 2008
    4551
    Quote Originally Posted by JEST View Post
    Here's the 5th reply in that "evil thread".....
    http://www.cnczone.com/forums/1181984-post5.html
    Jun 2008
    1838
    Works fine on drilling, you just have to make sure you have the default machine selected BC_3x_Mill and the BC_3x_Mill.Pst selected, you will probably have to do a bit of work on the Post to get the exact code for your machine depending on what it is but the Post is a "Fanuc-Generic" post so for most folks it won`t be a million miles away.
    See attached files, they should get you started, remember just use the BC_3x_Mill machine and Post set under your :-
    Milling Tools > Part and Default > Current settings and make sure you set it to be the default under the Part > Current Settings.
    The attachments have the BobCAD file, the G code file (NC) and the BC_3x_Mill.Pst that was used to create the code.
    Regards
    Attached Files Attached Files
    Sep 2010
    145
    I dont know if this will apply to any of you guys but.
    After I updated my laptop I had probs with the post.
    I did all the setting etc changes that have been mentioned
    What a found was that when I moved my post file around it would sometimes drop the end part (mill pst) so the post engine wouldnt find the post.
    When I got that figuered out it worked fine.
    Though, I havent ran the G code yet
    However my laptop also has lost my "pro" Lic box so I may have other system problems goin on.
    Jun 2012
    514
    guys i have been using the new build for 2 parts now...i had no issues with the post.... i selected bobcad 3mill as machine and then selected hass oem mill...works fine
    HOWEVER there are few bugs i have seen as of today...but that is not post related more along the lines things changing when i save a freaking file!
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
    Nov 2012
    You can update this from the internet by online for some paying to the company and the payment will be from your credit card number and deduct the money ferom your bank account you can try to login directly from the software's official web site and update this directly from the comapny...
    Aug 2022
    Re: updates made program worse!
    Here's my response: interesting posts. I agree. And I strongly advise you to pay attention to Andersen. It is a custom software development company that takes on difficult challenges and creates unique products. Its automotive software experts will work out your solution and lead the discovery phase of the project, while developers will assist in bringing it to life.
    Aug 2022
    thanks!
  1. Not loading program made in CAM software.
    By Boss&Sons LLC in forum Milltronics
    Last Post: 08-09-2012, 03:59 PM
  2. Replies: 4
    Last Post: 03-11-2012, 12:14 AM
  3. X4 updates????
    By WingNutz in forum Mastercam
    Last Post: 10-27-2009, 06:52 PM
  4. Worse than the devil we know: Story is the definition of irony
    By dynosor in forum Environmental / Alternate Energy
    Last Post: 06-28-2007, 07:23 AM
  5. 4.0 updates ?
    By bobleecnc in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-05-2004, 01:48 AM
