601,789 active members*
3,044 visitors online*
Results 1 to 6 of 6
    Sep 2010
    135
    USB 2 31i-model B5
    Hello all,
    Anyone would post the step by step on how to download a .nc program from a USB to the memory of the machine?
    And, how to run from the USB directly.
    control, Fanuc series 31i-model B5
    cheers
    Re: USB 2 31i-model B5
    You can NOT "Run" from the USB directly, Fanuc doesn't allow it. You must change parameter 20 to 17 then you use the same steps as you would for the memory card.
    Sep 2010
    135
    okay,
    I was able to run the program with the copy function from USB to /user, I don't remember anymore what I did...
    can you post on here the step by step on how to download a .nc program from a USB to the memory in this case, to /user dir?
    G-Code Program Restore
    To restore files using the ALL I/O screen, the I/O channel must be set to 4 for memory card and 17 for USB, and EDIT mode
    must be selected.
    1) Select EDIT mode on the operator panel.
    2) Press the SYSTEM button on the MDI key panel.
    3) Press the right CNC soft key untill you see ALL I/O
    4) Press the Program soft key on the CNC menu.
    5) A directory display of the card/USB contents appears…
    6) Press the OPRT soft key on the CNC menu.
    7) Press the F INPUT soft key on the CNC menu.
    8) Enter the file number of the Part Program file you want to load.
    9) Press the F-SET soft key on the CNC menu.
    10) Press the EXEC soft key on the CNC menu.
    The message INPUT will flash in the lower right corner of the display.
    Sep 2010
    135
    Thanks!!!
    cheers
    Tony
    Quote Originally Posted by drdos View Post
    must be selected.
    Late to the party, but I have a slightly different problem, I can copy paste a program from usb to the internal machine memory, but I can't copy paste a program from a network folder. I set up FTP communication (fanuc as FTP client), and I can see the files in the remote folder from the machine, but when I try to copy paste those files to the internal memory so I could run them, I get an error "can not copy/move".
  1. Replies: 2
    Last Post: 04-24-2018, 09:48 AM
  2. Replies: 4
    Last Post: 04-03-2018, 07:21 AM
  3. Manuals for Wasino Model LG-71 Turning Center and Mori Seiki Model MV-40B VMC
    By innovativeiron in forum Machinery Manuals / Brochures
    Last Post: 11-07-2013, 02:28 AM
  4. surface model vs Solid model machining
    By Marcutous in forum Daewoo/Doosan
    Last Post: 12-02-2012, 03:45 PM
