543,673 active members*
2,262 visitors online*
IndustryArena Forum > CAD Software > Logic Trace CNC/DXF > using a live edge piece as a frame around an object
Results 1 to 1 of 1
    Oct 2007
    830
    trace out all the parts to create the dxf files and then cut the horse
    using the CO2 laser out of black walnut and machine out the live edge wood
    to fit the horse using the CNC router
    https://youtu.be/wIzgleK0Tj0
    Attached Thumbnails Attached Thumbnails net1.jpg   net3.jpg   net4.jpg   P1030062.jpg
  1. using a live edge piece as a frame around an object
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 11-26-2020, 04:40 PM
  2. Replies: 1
    Last Post: 07-04-2019, 01:39 AM
  3. Replies: 19
    Last Post: 04-18-2016, 11:39 AM
  4. Object osnap to another object?
    By fordav11 in forum Autodesk
    Last Post: 10-01-2012, 03:28 AM
  5. How to remove wire frame from 3d object
    By LockTech in forum BobCad-Cam
    Last Post: 03-06-2011, 08:19 PM
