600,886 active members*
2,770 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Using a torodial power supply with CNC Plasma machine question
Results 1 to 4 of 4
    I am building a CNC plasma table and have a 1200 watt torodial power supply to power my stepper motors. I have been wiring up my other power supplies and testing for continuity as I go along. My input is 115vac (US). The neutral and hot wires are isolated thru out the system so far until I add the torodial power supply. It has 2 red wires that are supposed to be tied to neutral and 2 black wires that are supposed to be tied to hot. When I do that, the other hot and neutral wires now have continuity between them. They were isolated before. This doesnt seem right. It seems that there should be something between the torodial power supply and the other components of the system. Am I missing something?
    Attached Files Attached Files
    Dec 2003
    24235
    Re: Using a torodial power supply with CNC Plasma machine question
    There appears to be something bogus about the instructions, with ref to the 240v connections, but The connections seems to be OK for 120, i.e. two red together & two BLK together for 120vac .
    When these pars are powered, you should have the correct secondary voltage, if the RED's & BLK's were wrong, the transformer would overheat?
    I assume you want to power on 120V?
    Albert E.
    Apr 2018
    141
    Quote Originally Posted by dovrosenberg View Post
    I presume you are referring to continuity checking with all power disconnected? If so, I don't see a problem -- the two coils that are the primary side of the transformer are just long coils of wire. If there was no continuity between hot and neutral it would be a defective transformer.
    Its after power is applied that the transformer creates 'back EMF' which in effect is resistance that prevents what would otherwise be a short circuit.
    As for the PDF, the instructions more or less say with 240VAC hook up the the primaries in series, or with 120VAC hook them up as in parallel.
    - - - Updated - - -
    Dec 2003
    24235
    It is the parallel hook up that is critical, if wrong , IOW both windings have to be in phase.
    Albert E.
  1. HYPERTHERM power supply Plasma cutting machine
    By judy09 in forum Want To Buy...Need help!
    Last Post: 11-08-2016, 09:37 AM
  2. New plasma power supply
    By jason_alex in forum Waterjet General Topics
    Last Post: 11-18-2014, 02:50 AM
  3. Plasma power supply problems
    By matttargett4 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-14-2013, 02:48 PM
  4. Plasma power supply
    By Jonp in forum Waterjet General Topics
    Last Post: 12-18-2007, 09:39 PM
  5. What power supply for my bench top cnc machine
    By xcphil in forum Uncategorised MetalWorking Machines
    Last Post: 04-17-2006, 07:47 PM
