548,684 active members*
2,199 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Using Fusion 360 CAM
    Oct 2016
    8
    I am trying a simple program of fusion 360 CAM, but when running the program on my new SYIL X7, offset is set on top of the material in G54, but somehow my facemill, takes NO material during facing off. Haven't run the entire program yet, only because I'm very careful trying to do first cuts on my brand new machine. But why does it take any material during facing?
    Dec 2013
    5185
    Re: Using Fusion 360 CAM
    Maybe your top Z 0 is not set exactly correct. What does the DRO read when it is doing the facing cut?
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    635
    Double check your stock set up. Check that you have the origin in the right spot.
    Check your depths. Is your depth defined correctly?
    Check the "Stock to Leave" option. Make sure there is zero stock if that's what you need.
  1. Fusion 360 cam help
    By Lsilva81 in forum Autodesk CAM
    Last Post: 12-31-2020, 01:56 PM
  2. Alternatives to Fusion 360 CAM
    By datas_brother in forum Uncategorised CAM Discussion
    Last Post: 11-24-2020, 09:23 AM
  3. attempting first CAM on fusion 360
    By tkms002 in forum Autodesk CAM
    Last Post: 05-11-2019, 06:04 PM
  4. Fusion 360 Assembly to CAM
    By ozzie34231 in forum Autodesk CAM
    Last Post: 03-19-2017, 07:19 PM
  5. Parts made with Fusion 360 CAM
    By alan_3301 in forum Autodesk CAM
    Last Post: 09-11-2015, 11:58 PM
