585,956 active members*
4,381 visitors online*
    Using two KStep board
    Good day!
    We are going to use two KStep board in one mashine (using one KFLOP).
    1. How to conect KFLOP with second KStep board? (what JP we need to use?)
    2. What additional connecting wire we need to use? Can we order it in dynomotion?
    3. We are going to use two stepmotors NEMA 34 - it is 5,6 A. KStep has limit 5 A. Is it possible to use NEMA 34 with KStep?
    May 2006
    4045
    Re: Using two KStep board
    See here.
    If you order the boards together or tell us when ordering how they will be connected we include the inter board cables.
    You should be able to run the motors at 5A. Holding and low speed torque will be less but higher speed torques will likely be the same which is where it is mostly needed.
    TK
    http://dynomotion.com
  1. kStep board warms up to 75 degrees
    By RuslanRobot in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-02-2021, 07:37 PM
  2. 2nd kstep
    By Gregore in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-08-2017, 07:13 PM
  3. Reading KStep board bits? How to??
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-28-2015, 02:35 AM
  4. Replies: 6
    Last Post: 08-21-2015, 07:24 PM
  5. KStep Motor 0
    By sdavenport in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-14-2015, 05:24 PM
