499,508 active members
6,383 visitors online
    Oct 2007
    427
    Question v26 drag knife support?
    I have v26 is there options for using a drag knife and adding corner actions??
    if not, is there free software out there for doing this?
    thx
    Junior Member
    Feb 2013
    629
    Re: v26 drag knife support?
    I remember seeing this discussed on the Mach3 support forum, it may be worth searching there for "Drag Knife", I didn't read in any detail as my only application would be vinyl stickers and I use a vinyl plotter for that.
    Jun 2008
    1713
    Not for V26, it does now exist in V31 though but that would cost a chunk of change to upgrade from V26 to V31
    However you could try the software at this link to a free software that might do the job for you, it does say that it supports Drag Knife operations
    https://sourceforge.net/projects/dxf2gcode/?
