545,781 active members*
2,194 visitors online*
    Jun 2021
    Velocity if rotate around TCP
    Hello,
    if I want to rotate around the TCP, there is no velocity in mm/s or so on since the tool rotetes but stands still. This is the case if I want th give the tool a new orientation.
    So, there should be a G-Code to set pure rotation velocities. I could not find something like this, since in general the tool tip ist displaced too, when I command a movement.
    And, I think the rotation velocity should be the same if there a rotation is commanded around a point that is extremely near to the TCP. This seems to be self-evident (?).
    Thanks in advance
    Re: Velocity if rotate around TCP
    In some controllers you can switch between two feed definition : check G93 / G94
    basically if you turn around tcp you can activate G93 and declare a Feed F, the move will take 1/F seconds (or minutes) to complete.
  1. modbus tcp
    By fishin_fl in forum Spindles / VFD
    Last Post: 08-24-2013, 03:37 AM
  2. ip/tcp vs. com communication
    By Rylee in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-07-2011, 08:11 PM
  3. Ip/tcp
    By wireguy in forum Computers / Networking
    Last Post: 09-06-2006, 06:11 PM
