525,618 active members*
2,499 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > General Laser Engraving / Cutting Machine Discussion > vevor 80w co2 laser cutter manual lower the lifting plataform
    Hello again guys!
    I got a vevor 80w co2 laser cutter, this is my first laser machine that the plataform does not comes up/down with the control panel.
    I need lower the plafaform like 1/2 inch so the material can be feed from a vent on front/back of the machine, so I can use long stripes of material, instead of squares with the exactly working area.
    Does anyone knows how to lower the lifting plataform manually?
    Thanks!
    Mar 2016
    90
    Re: vevor 80w co2 laser cutter manual lower the lifting plataform
    HAVE YOU GOT A PIC OF SAID MACHINE??
  1. vevor 80w co2 laser cutter will the legs come off
    By taffy1500 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 07-01-2020, 09:50 AM
  2. Lifting Tormach lathe from pallet without lifting kit
    By Spiffy Lab in forum Tormach Slant Lathe
    Last Post: 01-02-2020, 06:20 PM
  3. China first set combination of fiber laser cutter &co2 laser cutter ,in one machine
    By laserliu in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 03-13-2017, 09:00 AM
  4. Request for Manual for CM120 laser cutter/engraver
    By surfsen in forum Machinery Manuals / Brochures
    Last Post: 10-01-2011, 08:10 AM
