535,630 active members*
3,408 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF3-SS : Spindle Motor Failure x 2
Results 1 to 10 of 10
    Mar 2008
    22
    Hey Guys
    I have an older post here about some noise coming from our 2005 VF3SS.
    We have since put about 2-3000 hours on it since we took delivery and mid September, we had the Motor replaced.
    We are a 18 hour a day shop, and we run at 12K all the time. Word on the street is that Haas has gone with 4 motors, Lincoln, Baldor, Baldor-Haas, and Yaskawa.
    2 Weeks later, we were missing tool changes, and couldn't orient spindle. After trying to swap out the Delta Wye Contactors, the tech figured out it was the encoder belt.
    You swap out a motor for 4k and you don't include some normal wear and tear items in the "kit"?
    Well, fast forward about 2 months, and based on an associates opinion, the Spindle motor is bad again. HFO Torrance will be out to check out the machine, but I will be pushing them HARD to replace it with a better Baldor-Haas or Yaskawa motor.
    I am a big Haas fan. My company jocks them and they jock us on their Facebook page. I really want to continue to invest in their machinery, but uptime is critical. When we aren't making products to ship out the door and my guys can't come in to work, I take it very seriously.
    Anyone else out there have a similar issue?
    Gold Member
    Mar 2010
    1837
    Nope
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Mar 2008
    22
    With the motor out
    Mar 2008
    22
    New motor
    Mar 2008
    22
    Old motor
    Re: VF3-SS : Spindle Motor Failure x 2
    Can you please send the motor details or the data sheet with encoder details connection details.
    thanking you
    Jan 2005
    11929
    Quote Originally Posted by ccjung View Post
    Hey Guys
    Sounds like you are not doing normal maintenance the encoder belt is nothing to do with the motor being changed, ( although they could of looked at it when the covers where off ) if you are running the motor at 12,000 RPM 18hr a day 7 days a week I would say they will not have a very long life unless the motor is rated for 12,000 RPM it is not going to last that long the Yaskawa might be the only motor in you list that has that rating, the other motors sure don't, I would be surprised if they are rated at 8,000 RPM continuous
    The encoder should of been the first thing the Tec checked when a spindle won't orientate correctly, there must of been another reason for him to look at the contactor, most likely was faulty from age
    Every part only has a service life
    Mactec54
    Gold Member
    Mar 2010
    1837
    9 year old post.
    Jan 2005
    11929
    Quote Originally Posted by Machineit View Post
    9 year old post.
    Wow got cought with that one when someone posts and opens up an old post I did not look at the date before I replied what I added may help someone with a problem like this I'm sure others have had failures with over working these spindle motors
    Mactec54
    Gold Member
    Mar 2010
    1837
    Happens to all of us, done it myself. Comes from a desire to help others.
    Mike
  1. Failure of PWM mode to control machine spindle motor
    By gurukrupaelec in forum Mach Software (ArtSoft software)
    Last Post: 04-16-2010, 03:26 PM
  2. motor failure
    By 545Kurt in forum Mini Lathe
    Last Post: 02-25-2009, 06:43 AM
