600,838 active members*
3,318 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > VF6SS “searching for languages…checking usb”
Results 1 to 5 of 5
    Powered up machine that has been sitting under power for a while. When it starts boot up the screen shows this “searching for languages…checking usb”. A few other threads showed needing batteries replaced, so I did that while machine powered up. Still obviously same issue. The machine did not come with usb back up. Anyone got ideas on next steps? Not wanting to run up huge service bill.
    Dec 2013
    Re: VF6SS “searching for languages…checking usb”
    Are you saying your machine has an original floppy drive and no USB, but it is checking for an USB?
    or
    Your machine has an original USB drive with that error message?
    or
    The floppy has been removed and a USB floppy drive emulator has been installed?
    Quote Originally Posted by saltfever View Post
    or
    or
    Has original USB that is still intact.
    Dec 2013
    I'm guessing you tried to start up with a USB inserted? Re-start without it. IMHO, seems like the USB is corrupted.Try a new USB stick. "Searching for language" is one of the first boot-up instructions. The boot instruction may have been corrupted by "low battery" or during the battery change and that unfortunately may require a call to your HFO. All the best.
    I mis understood what you were asking, there is a USB port that has nothing in it. Another thread I read with a similar issue makes it seem like the control is looking for a usb to be inserted for it to download a language file.
  1. other languages for MadCam
    By figurenholz in forum MadCAM
    Last Post: 02-01-2018, 02:31 PM
  2. Searching Arduino's code or windows pc program to drive big stepper motors via usb
    By takis1234 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-20-2015, 09:58 AM
  3. Searching Arduino's code or windows pc program to drive big stepper motors via usb
    Last Post: 05-19-2015, 01:24 PM
  4. CNC Manuals in all Languages
    By tanvon in forum Haas Visual Quick Code
    Last Post: 02-12-2015, 05:45 AM
