585,759 active members*
3,821 visitors online*
    Aug 2010
    13
    Question VF9 Y Axis Problems
    Hi Guys,
    Have a problem with the y axis encoder on my haas vf9-40. Machine is 2013/14,
    The problem occurs when i go to move the y axis after referencing the machine.
    I get to move the y axis in about 2 inches and get this error, Error:424 Y Axis Secondary Encoder Position Mismatch. Have tried switching the connections for the x & y cards in the rear panel but the problem does not follow, The problem stays on the y axis. I have tested the Y drive motor my putting a piece of metal over the y prox sensor under the y axis slideway cover and referencing the machine, this causes the machine table to move in and get past the problem area. Any help would be appreciated. Thanks in advance. Have attached some pictures, might help someone diagnose the problem easier.Click image for larger version.
ID:	450837Click image for larger version.
ID:	450839Click image for larger version.
ID:	450841Click image for larger version.
    Jul 2020
    7
    Re: VF9 Y Axis Problems
    haas says to cycle the power and try again, but its probably the motor itself, the cables, or maybe even the mocon, try to narrow these down.
