594,860 active members*
5,642 visitors online*
    Apr 2011
    13
    VFD Comport Problem
    I’m running Mach3 with a Smooth Stepper, a VFD using a 485USB for spindle control and a P1A MPG Pendant.
    When I start Mach3 I sometimes get an error message that it can’t read the port settings for the VFD and do I want
    to configure it. When I look at the device manager it shows com5 which is what is set in Mach3, but for some reason
    it’s not seeing it every time. The PC is running Win10 and I usually have to restart it or just Mach3 to get it to work.
    Has anyone had this problem and what the solution is?
    Sep 2024
    29
    Re: VFD Comport Problem
    Quote Originally Posted by golijoe View Post
    ok i understand
    Regards
    Pankaj rana
    Ansh Automation....Retrofitting expert noida
    Apr 2011
    13
    Any help would be appreciated.
  1. Ae-200 vfd problem mach3 rpm doesn't match with vfd
    By Chmfhm in forum Spindles / VFD
    Last Post: 05-20-2022, 06:46 PM
  2. VFD Problem
    By zullah in forum Milling
    Last Post: 08-02-2019, 11:42 AM
  3. Spindle Problem or VFD Problem?
    By twbaisch in forum CNC Machine Related Electronics
    Last Post: 06-10-2019, 07:33 AM
  4. VFD Problem
    By squirrel_41 in forum Spindles / VFD
    Last Post: 07-11-2017, 05:55 PM
  5. VFD Problem
    By jeffrey001 in forum CNC Machine Related Electronics
    Last Post: 08-21-2009, 10:54 PM
