528,005 active members*
2,582 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD manual for MK100-2S2.2G-DK
Results 1 to 7 of 7
    May 2019
    Does anyone have the manual for VFD manual for MK100-2S2.2G-DK
    Have attached pic of the manufacturer plate
    Sep 2005
    1740
    Re: VFD manual for MK100-2S2.2G-DK
    Quote Originally Posted by Ktmben View Post
    No picture and why do you folks by these drives without documentation?? Asking your Chinese vender would be the first place I would try.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Jan 2005
    11430
    So you have a CNC Control Panel with an open board VFD Drive there is a thread for these control boxes under 6040 I have some of there manuals but may not have your one you will need more information and take some photos of what you have inside the cabinet / box
    Mactec54
    Here is the manual you wanted.
    https://1drv.ms/b/s!AlWEvfzVs336oREF9zNq6qcxH5kF
    This saved the day for me cheers for the manual. Which setting if to allow Mach 3 to control the spindle speed?
    Apr 2020
    3
    Quote Originally Posted by Abersmith View Post
    Did you ever figure this out? I have a machine with the same VFD and I can't seem to get mach3 to control the spindle.
    Hello,
    I have a CNC6040Z S80 with a MK100-2S2.2G-DK in the black box.
    In the manual there is no info about RS485 / Modbus protocol...
    I have modified:
    P0-02 to 2 for communication command channel
    P0-03 to 9 for communication command for frequency control
    Modbus rtu request:
    with 01 06 20 00 00 01 I can RUN
    with 01 06 20 00 00 05 I can STOP
    But
    with 01 06 20 01 0F A0 i can't modify frequency.
    Did I miss something ?
    or Have you modbus documentation
    thanks a lot
    Laurent
    excuse my english i'm french
    i have a question for the frequency inverter MK100-2S1.5G-DK. I want to start my Spindle via CNC Software. My CNC6040 is from the Vendor "SXCNC".
    Has anyone ever wired the frequency inverter to the mainboard JP-3163B?
    Can you have a look to my Post here i worte all in details about my question?
    https://www.cnczone.com/forums/chine...ml#post2402392
    Regards Raini
  1. Replies: 0
    Last Post: 08-06-2018, 05:45 AM
  2. Replies: 0
    Last Post: 03-18-2016, 10:55 PM
  3. For Sale Complete Maho MH 600E Manual, + Philips 432 Programming Manual
    By HKgunslinger in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-08-2012, 08:09 AM
  4. Mecof CS100 manual & Zayer KM 8000 manual
    By australia in forum Uncategorised MetalWorking Machines
    Last Post: 02-25-2011, 11:59 AM
  5. Replies: 0
    Last Post: 06-17-2010, 12:59 PM
