585,949 active members*
4,030 visitors online*
Thread: VFD Problem
    Jun 2019
    VFD Problem
    Dear all. i have FUJI VFD G9S.which is connect with single phase 220V. from last 3days i have problem that when i try to change any parameter i can't change it due to it is display (Data procit)i try to change prameter (95)data protiation which is 0=data changable and 1 is data not changable. i try it to change feom 0 to 1 and save it and try to change it from 1 to 0. its changable when i try to save its display data saving. but when i try to change other parameters its no change and continue display (DATA PROCTIC).can any one helpe me how to solve this problem. Regards.
    Aug 2019
    firstly you Noted the Present parameter value then you Reset the drive.After completion the process you are set the value
