When the drives are turned on, the LED on the VFS5 flashes 5 times. + - 18 volts available 10 volts available.
MOTION LINK IN TERMINAL ERROR 83 AND 84
1.Sabre1000 machine
2. No wiring diagrams!
1.Sabre1000 machine
1) if I'm remembering correctly, error 83 and 84 are typical of what I see when someone unfamiliar with Motionlink uses it and enters invalid commands so they may not be related to your issue. It is also normal to see err 14 power bus and drive powered up messages, but since it only stores the most recent codes, these may have been pushed off the list.
2) You can get the wiring diagrams from Fives, they will want the diagram number on the serial number plate. These won't likely help much with the current VFS5 issue, but it is always better to have them when working on a machine.
Can anyone help with the wiring diagram?
My electrical cabinet number
91203230
Thank you!
Our fan crashed on VFS5.
vfs5 monitors the presence of a fan?
Is it possible temporarily without a fan?
When the light flashes it is because of a bad battery, contact kilroy corporation , kilroycorp.com ???
Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
The LED is not blinking now.
When all voltages are switched on:
+ 10v
+ -18v
+ 24v on c2 pin 6.9
jumper on S7 MOTION, LIMIT
And on PSR4 / 5
Shines:
sys ok
Cpu
FAULT
RELAY
AKTIV NO!
I checked the resolver with 18om, 18om, and 36om
On TERMINAL (Motion Link) when you enter EN (ON), appears
ERROR 83 ...
AND ALL
What else can I check?
now shines when voltage is applied
ACTIV
CPU blinking unpleasantly
How to do autoload correctly?
CPU blinks continuously
It is now detected when the voltage is switched on
ERROR 27 ”R / D JUMPERS” SEVERITY 3
Either the jumpers on your BDS5 MC2 card are incorrectly set or the wrong
TL has been loaded. Contact the factory.
What to do with it?
Who has a TL file on VFS5?
There are instructions for creating a VFS5 spindle drive configuration?
Or is MOTION LINK + enough !?
Who can I ask questions?
Does the forum work or not?
How can I see anything from the configuration in MOTION LINK TERMINAL?
What are the commands?
Only ON, EN works in the TERMINAL.
Other commands don't work!
What am I doing wrong?
I think you need to have the VFS5 Drive Repaired; they will replace bad Capacitors; RTC-Clock Chip with internal Battery and reload the Spindle Program and STD variables. User Variables are setup for the particular Machine Type and Spindle Gear Ratios and MAX RPM. The Rectangular Chip on the Front Top tells them what to reload. We quote Inspect and advise 1-800-534-4750 (Fives-Cincinnati-Repair Group )
What commands can I use in TERMINAL?
--> ERR HIST (then Enter will display your error History)
You do not have the tools to reload the VFS5 Program and Variables.
For Inspect and advise quote contact 1-800-534-4750 (Fives-MSI-Cincinnati-Repair-Group)
A neat reference site is (KOLLMORGEN BDS4/5 – CNC_Principle_Repair) unsecure
err 18 line 246 "EN" BAD TL
what to do about this error?
Is this error both hardware and software?
