525,379 active members*
2,660 visitors online*
    Jun 2016
    20
    Victor CNC Lathe 1840[ DEL
    Hello, we have a Victor CNC Lathe 1840i DEL, this machine has a noise in X axis when rapid traverse. It holds tolerance well and. leaves a good finish, juat the noiae when rapid. Also. would like to know where to get maintenance manuals for this machine. Thank you.
    Apr 2007
    143
    Re: Victor CNC Lathe 1840[ DEL
    barnesven,
    Most likely the noise you hear is coming from the ballscrew support bearings. Over time, but certainly following a crash or crashes, the bearings get microscopic flat spots on them that causes the noise and accelerates the failure of the bearing. If you can live with the noise and you're still able to hold good tolerances, you've got some time before the bearings truly fail. A simple backlash test will give you an idea of the degree of failure you're already dealing with. If you've got more than .002" backlash,your bearings are disintegrating. :wave:
    Dec 2009
    619
    Post a picture with the machine,i might have some manuals
  1. Should I use my Smoothstepper or Galil DMC 1840 for Router or Lathe?
    By kevincnc in forum DIY CNC Router Table Machines
    Last Post: 05-13-2013, 03:56 PM
  2. Fanuc 10T on Victor lathe
    By Chais82 in forum General MetalWork Discussion
    Last Post: 10-23-2012, 02:26 AM
  3. Victor Lathe Manuals For Spindle
    By RoundieLand in forum Uncategorised MetalWorking Machines
    Last Post: 09-08-2009, 09:11 PM
  4. Ameritech lathe pl-1840 info
    By Turbo67cnc in forum Shopmaster/Shoptask
    Last Post: 05-29-2006, 06:29 AM
