601,787 active members*
2,763 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Victor TNS-2 Fanuc 10T-A 1988 Hydraulic Activated Tailstock not Working
Page 1 of 2 12
Results 1 to 20 of 23
    Jan 2010
    56
    First of all Wish you all a Happy New Year! Hope you can help me out with a problem I am having with an old Victor TNS-2 Fanuc 10T-A 1988 Lathe, which is working perfectly, its in very good condition..
    only problem I have is that I am not able to Activate the Hydraulic Tailstock, not sure of the procedure.
    By the way, Tailstock quill switch is working fine!, There is a Switch Tailstock Body Retract and Advance, which doesnt do anything on the main OP panel.
    Maybe im needing an M-Code?, or the turret must be in an Exact position?
    Its a positioning type Tailstock with a Hydraulic pin that engages with the turret, and there is a larger hydraulic piston that clamps into the Guideways.
    There Is a total of 4 Endstop switches which I recently replaced with Originals.
    -2 Switches for the correct positioning of the Turret so that the Tailstock engages with the Pin.
    -2 Switches that feedbacks that the Pin is either retracted or in Position and is engaging the Turret.
    Tailstock Quill works fine, Im also able to activate everything via the Solenoid valves manually.
    Anyways,it just occured to me that Im going to check the relays today, and if I find a solution, I´ll write it up here.
    hope you can help me out!,
    regards!
    Aug 2007
    840
    Re: Victor TNS-2 Fanuc 10T-A 1988 Hydraulic Activated Tailstock not Working
    Do you have schematics or ladder listing? Find places with corresponding comments (tailstock...) and upload copies
    Jan 2010
    56
    Hi Guhl,
    Thanks for your reply, I´ve not been able to see the ladder, I was trying to access it, from there I may be able to look which M-Code it might be.. In fact im not able to find it or dont have access to it.
    Control is a Fanuc 10T-A.
    Aug 2007
    840
    NC/PC -> PCLAD doesn't work?
    Do you have schematics?
    Jan 2010
    56
    Guhl, I pressed NC/PC and ladder was there, thanks.
    Should I take pictures of the whole ladder?
    BTW just went through the whole Ladder about 532 Pages, and didnt find anything With tailstock.
    Just Move/SUB/TMR etc...
    Dec 2009
    1024
    post a picture with the operator panel.
    As far as i know must be a push button from operator's panel to take the pin out.
    if you have the elctrical book and ladder we can help you.
    if i were you i do like this:
    -scan the electrical book and make a pdf document:
    -take pictures with every ladder page and make a pdf document:
    with these 2 send to us we will help you shortly now and in the future.
    Good luck!
    Aug 2007
    840
    We need a page from electrical schematics from winch we could determine physical output for tailstock. Then we will tell you what to find in ladder.
    Jan 2010
    56
    Attachment 303206
    Hi, Picture is attached.
    Im sorry to say that I don´t have an electrical book, So I will have to take pictures of the ladder.
    Might Take a while..as there are almost 532 pages :tired:
    Is there any other possible way to do this?
    Thanks,
    regards,
    Alberto
    Aug 2007
    840
    Go to page NC/PC -> PCDGN, type Y0 and push SEARCH
    You will see the page with physical outputs, take a photos of all pages where Y-signals are signed (usually they are)
    Jan 2010
    56
    Hi!,
    Just to let you know I was able to resolve the Issue, the Procedure is in the attached picture..Found it somewhere online, it was for a model TNS3 slightly newer version of the Lathe.
    Im not sure the Tailstock can be programmed with an M-Code. Anyways thank you for your help. Leaving the solution here posted.. !
    Attachment 303214
    Dec 2009
    1024
    i was sure the solution was from operator's panel
    Jan 2010
    56
    Correct Zavateandu!, But the procedure is that
    1.) X axis must be Homed
    2.)Turret must be in front of the Tailstock (There is an arrow)
    3.)Mode must be in RAPID 50% or less
    -then TAILSTOCK retract button on Operator Panel must be pressed until the Turret touches the home Switches. The Pin engages automatically and you can move the TAILSTOCK backward or Forward. After you stop pressing this switches 2-3 seconds later the Tailstock locks into place
    Dec 2009
    1024
    yeah you are right.
    i am service man on the victor machines and the TNS 2,3 i worked some year ago ,6 or 7 years ,can't remember and i knew it something from operator panel but i forgot and i couldn't remeber.
    Nowdays i work on the new models of Victor Taichung machines and the new models have the programable tailstock with a M code.
    still i got pictures from my shop deliverying one of that.
Name:	Lungimi Sufe ridicare Victor TNS 2 si 3.JPG
    Jan 2010
    56
    Zavateandu,thats exactly how my machine looks only that mine has a brand new paint job. Now that you say that you are a service man on the victor machines..today I decided to take of the slide cover that is protecting the ballscrew, and I found myself with a In perfect condition ballscrew(Which is by the way good news) but there is absolutely no lubrication line or whatsoever. Is this normal?
    I know this is a little bit off Topic, but its also an important part of this machine model..
    Attachment 305508
    Sent from my SM-G903F using Tapatalk
    Dec 2009
    1024
    as far as i know the lubrification of the Z ballscrew is coming through the Z axes bed straight into the nut so you can not see it untill you dismount the nut.
    normally must be a little oil on the ballscrew if you check closer.If not ,you must check if oil is going to the nut(check the photos )
    Attachment 305570
    Jan 2010
    56
    Hi!,
    Thanks! Now all is clear, solved the problem one of those lubrication lines was clogged. Cleaned the filters and the lube is working again seems I missed the first time where the distribution was.
    Attachment 306074Attachment 306076
  17. #17
    Jan 2010
    56
    Hi!,
    Its me here again with the Victor Tns-1 Machine!
    Hope you are all doing fine. Given the fact that this post has something to do with lubritcation, does someone have an Idea which parameter can be used to program/reduce pumping time values of the lubrication pump?
    I think its using a tremendous amount of oil. I would like to be able to control this.
    Hope someone has an idea..
  18. #18
    Dec 2009
    1024
    should bein diagnose screen)
    D410-----Time interval between lube pump operation while machine is running
    D415-----Time interval between lube pump operation while machine is idle.
    The value of these 2 counters are in seconds so for example if is 120 you will have 120 sec--2 minutes interval
    D370-----Length of time lube pump keeps running after pressure check when pressure remains abnormal until alarm is given
    D375-----Length of time lubrication is pumped while pump is on
    D395-----Time interval before pressure is checked will pump is on
    These timers are on miliseconds,ms,so a value of 15000ms---15 seconds
    Please check and let me know if you need more help
    Have a good day.
  19. #19
    Hey been trying to find the right thread to jump in with my issue. Purchased a used Hitachi Seiki HT-25 and put it in my garage. Took me about a year but finally got power to it. Been working through sticky micro switches and learned about the Z axis thrust assembly, BANG, lol. Had issues getting the spindle to operate. Everything was working in MDI mode except any turning codes. M3/M4 after playing with M40/ M41 and spinning chuck manually the machine came to life. Shut it down to replace all covers and wires and so on. Powered the machine back up and now nothing in MDI mode is working. I have 2 maintenance manuals and a operator's APPENDIXES manual. Not much from the manuals has been helpful to me. Any ideas would be appreciated.
    Sent from my SM-G950U using Tapatalk
  20. #20
    Also I think its M68/M69 the operates the hydraulic tail stock
Page 1 of 2 12
  1. Conquest almost working - no hydraulic pressure
    By rcpaisley in forum Hardinge Lathes
    Last Post: 09-06-2019, 06:27 AM
  2. 1988 Fanuc 0T-B Drip Feed?
    By wtopace in forum Fanuc
    Last Post: 12-06-2015, 05:56 AM
  3. Need info on Leadwell MCV-0 1988 with fanuc OMB
    By softselect in forum CNC Machining Centers
    Last Post: 02-20-2015, 10:24 PM
  4. Fanuc OM, Booster not activated at ATC Cycle
    By ThomasS in forum DNC Problems and Solutions
    Last Post: 04-28-2010, 01:53 PM
  5. 1988 Fanuc tape cut edm HELP!
    By rmilaser in forum EDM Discussion General Topics
    Last Post: 01-14-2010, 08:18 PM
