601,789 active members*
2,219 visitors online*
Results 1 to 4 of 4
    Feb 2023
    VM32 bearing advise
    Hi All
    I have a VM32 (bought from CNC4YOU) That I have fitted with a 3.6KW servo motor for the spindle drive. I have geared it 2:1 and this gives me a max spindle speed of 5KRPM. I am concerned about the standard bearings being upto this, bearing in mind the standard max speed was 2400RPM. I also designed and 3D printed a bush to help take out any movement in the quill/drive interface and that has made a massive difference to smoothness and noiuse,
    So was interested in what people thought about running the standard bearings or do I need to upgrade. (I will upgrade anyway but I want to cut some parts in the mean time)
    Cheers
    Bazzer
    Edited to add annoyingly I can't seem to rotate that picture now I have posted it :-)
    Edited again to add I can now see I have posted this in the wrong forum and should probably be in DIY CNC, but can't find a way of moving it or deleting it.
    Feb 2020
    6
    Re: VM32 bearing advise
    Hi, I have the same mill bought direct from Weiss. Do you have more details about your servo motor conversion?
    Apr 2005
    863
    I would monitor the bearing temperatures after a running-in period under no cutting load. I did a thread on this when I converted my machine to belt drive. There's a good chance it will be fine, but not 100% certain. Much will depend on the amount of preload on the bearings.
    I would be really interested to see details of your printed bush for quietening the machine down.
    LongRat
    www.fulloption.co.uk
    Mar 2025
    Hi, what the part number of bearing are you use for?
  1. bearing replacement / advise needed
    By teamjnz in forum Haas Mills
    Last Post: 03-19-2025, 08:49 AM
  2. New Build - PM30/AMA30/VM32 Type Milling Machine
    By men8ifr in forum Benchtop Machines
    Last Post: 04-22-2021, 06:57 AM
  3. Replies: 2
    Last Post: 07-23-2015, 05:53 AM
  4. Linear bearing system advise................
    By CNCexplorer in forum Mechanical Calculations/Engineering Design
    Last Post: 03-26-2012, 01:22 AM
