544,051 active members*
1,860 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC15 XT motor pulley and spindle pulley
Results 1 to 7 of 7
    Feb 2014
    182
    Hello I am looking to see if any can tell me the depth of the pulley when mounting to the spindle motor and depth of pulley to the spindle? Have new motor, spindle and both new cog pulleys. This is for a VMC15 XT 7500rpm spindle.
    Thanks for the help
    Oct 2008
    1549
    Re: VMC15 XT motor pulley and spindle pulley
    Let me take a look......
    Feb 2014
    182
    I appreciate you taking a look. I can't find anywhere in the manual that says the distances for the gates power cog pulleys. I think from the motor shaft end to the bottom of the pulley is .43". Would like to know for sure because you have to pull the motor back off to move the pulley. I think the spindle pulley is flush with the top of the inside of the pulley and the spindle shaft where the line markings are for the orientation.
    Oct 2008
    1549
    Those were the only measurements I had but maybe someone else can help with the dimensions you need.
    I snagged those a while back in case I ever needed them later. Hopefully not, famous last words.
    Oct 2013
    3
    if its a 7500 rpm pulley it should be the gates "poly chain" belt, and spacing. Unless you've got an odd belt setup, i've never seen a cogged belt on a fadal
    Feb 2014
    182
    Quote Originally Posted by tenchuuu View Post
    I meant to say Gates “Poly Chain.” Thanks for correcting.
    Aug 2009
    988
    ..spacely sockets aka.. and a boy named elroy. in the passed
  1. Motor pulley diameter
    By jeffrey001 in forum Tormach Slant Lathe
    Last Post: 02-23-2018, 03:22 AM
  2. Need spindle motor and pulley for a supermax ycm 40
    By jacklegjim in forum Want To Buy...Need help!
    Last Post: 07-18-2017, 06:03 AM
  3. Replies: 0
    Last Post: 11-07-2015, 12:04 AM
  4. Mutt Machine Motor & Spindle Pulley Combo
    By mikkojay in forum Benchtop Machines
    Last Post: 01-22-2008, 08:37 PM
  5. Motor pulley
    By JWOOD in forum Fadal
    Last Post: 03-31-2006, 10:45 PM
