585,991 active members*
4,725 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > VMX30U Door Interlock install
Results 1 to 6 of 6
    hello all, we recently purchased a used VMX30U and it did not come with the door interlocks. We purchased a door interlock kit from HURCO and it came with two locks, a harness and three relays. I’ve gone through the wiring diagram several times along with another one from the service manual and I'm confident the door locks are correctly wired but I’m still having trouble getting it hooked up in the cabinet. I was hoping someone has a machine with the door interlocks installed and would be willing to share a picture of the electrical cabinet, specifically the door interlock harness connections. On the CE diagnostic screen it shows "door open" and "door closed" but once its closed the doors remain locked even tho the screen indicates "unlocked". I am new to HURCO machines so any information or something i missed would be greatly appreciated! I know its hard to tell anything from a picture but I've included a picture of the cabinet for reference, ignore the messy wires, I'll clean it up once i figure out where they all go!
    Apr 2019
    58
    Re: VMX30U Door Interlock install
    Do you mean this one?
    Išsi?sta naudojantis SM-G960F Tapatalk 4 Lt
    That appears to be the same door lock but we have Winmax on this machine.
    Jun 2008
    1104
    Go to the Auxiliary page and select Utilities. Once there, go to Integrator Support and type the passcode 46268.
    Select Integrators and then N:95 parameters. Jump to parameter 230 and make sure it is set to 1.
    Aug 2009
    37
    Quote Originally Posted by bloke View Post
    We have gotten to this point, but when I try to disable it says we're not allowed. Any idea what the code is. 46268 gets us into ce diagnostics.
    Jul 2023
    I had an issue with the door being locked and unable to unlock so I turned parameter 230 to 1 and now I can no longer do anything with the door open and when I try to set 230 back to 0 it will not let me says CE diagnostic not changed not allowed. Can anyone help me to turn that back off so I can do tool changes and set ups with the door open
  1. Door interlock?
    By Edster in forum Fadal
    Last Post: 07-12-2014, 06:40 PM
  2. Door Interlock
    By akhilb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-16-2011, 10:46 PM
  3. DOOR INTERLOCK
    By gtrrpa in forum Mori Seiki lathes
    Last Post: 04-18-2011, 07:56 PM
  4. Please help-door interlock
    By em322 in forum Okuma
    Last Post: 01-19-2010, 09:54 PM
  5. Door Interlock
    By hatchmar in forum Fanuc
    Last Post: 12-30-2007, 01:52 AM
