504,510 active members
3,278 visitors online
IndustryArena Forum > MetalWorking Machines > Okuma > VOPRB on Okuma lathe
Page 1 of 2 12
Results 1 to 12 of 20
    Jul 2013
    21
    My Okuma lathe uses the EP-P300L-R controller. Can I use the program to on / off parameter 29 bit 1 with VOPRB code? (Image in attachment). Please help me. Thank for all
    Aug 2011
    285
    Re: VOPRB on Okuma lathe
    try
    VOPRB[29] = [VOPRB[29] OR 2]
    "Imagination is more important than knowledge."
    Jun 2015
    2796
    please, what is VOPRB ? kindly
    Jul 2013
    21
    Quote Originally Posted by kurmay View Post
    try
    I tried and encountered this error (please see attached image). Please help.
    Jul 2013
    21
    Quote Originally Posted by deadlykitten View Post
    Hi deadlykitten, I don't really understand.
    Jun 2015
    2796
    hey duongcave, why do you wish to change #29.1 ?
    Jul 2013
    21
    Parameter 29 bit 1 on my machine is used to on / off the "Cycles time check over" function. I have tried on / off manually. I think the VOPRB code can replace me doing that
    Jun 2015
    2796
    please, what is doing this " cycles time check over function " ? inside manuals is nothing about it; only in the machine catalogue i find that "An alarm occurs after the completion of a set cycle " ... i have no clue what this function is doing ...
    it seems like the controller does not support the voprb system variable
    Jul 2013
    21
    Right. Unfortunately
    Apr 2009
    1121
    I think you can do this via m code on your machine. Don’t remember it off the top of my head, check your list in the machine or I’ll dig it out when I get to the office.
    Experience is what you get just after you needed it.
    Jul 2013
    21
    Quote Originally Posted by OkumaWiz View Post
    I checked and only M code to on / off "STM check over". I'm not sure how it works. But it is not what I need now.
    Jun 2015
    2796
    please, what is voprb ? and how to use it ?
    oh, i just discovered what is the "
    cycles time over check function " : it verifies the duration of the cycle ... hmmm so far i could not find a thing, because i was looking for " check over " instead of " over check "
    however, i am not sure if this function delivers nice results; it's estimations should be similar to the "
    cycle time calculation function" ( or maybe these 2 functions are one and the same ? ), and i have seen differences between real time and estimated time; of course, maybe there are a few parameters that can be adjusted, but with so many ctr & motions stuff, i really doubt that the controller can estimate it's self
    to control such things, i don't relly on special functions, but on a real baseline; do you wanna know what was the machine doing in 2015, at 10.35am, 1st monday of july ? i can tell that, with <1 second accuracy; do you wanna know the spindle time on 2016 april? again, my methods are not designed to verify or check wrong operator behaviour, thus their output can be messed up, but this can be prevented, only if needed; i said this, because i suppose that you are still hunting your operator
    about ' cycle time over chek ', i also found these :
    ... #29.0
    STM time over check ON (R-side)
    ... #29.1
    Cycle time over check ON (R-side)
    ... #44.0 STM time over check ON (L side of parallel two-spindle machine)
    ... #45.0 STM time over check ON (L side of parallel two-spindle machine)
    ... #45.1 Cycle time over check ON (L side of parallel two-spindle machine)
    * it seems like there is no bit to control the L-side of a normal lathe ( 1 spindle, 1 turret ); of course, manuals translation from japanese is not accurate, especially in such wild areas like the bits, so i would test them
    and these optional M's:
    ... M124 STM time over check ON
    ... M125 STM time over check OFF
    ... M677 Time over check ON
    ... M678 Time over check OFF
    ... M725 Loader time over check start
    ... M726 Loader time over check stop
    kindly
Page 1 of 2 12
  1. Okuma lb6 cnc lathe
    By As9100d in forum Okuma
    Last Post: 04-28-2019, 06:17 PM
  2. Okuma lathe help
    By rustedhooks in forum Okuma
    Last Post: 12-16-2018, 06:53 AM
  3. OKUMA LH 35N CNC Lathe
    By raviswanadha in forum Okuma
    Last Post: 02-16-2018, 09:08 AM
  4. Okuma LB 12 CNC Lathe
    By rajappa in forum Okuma
    Last Post: 10-09-2014, 12:19 AM
