I'm looking for any information, parts listing, Mach3 XML file, basically anything to do with Vortech Cnc routers.
Best Regards,
Tom Martin
Best Regards,
Tom Martin
Hopefully you got that worked out. Maybe was just a matter of learning Mach 3.
I also have a Vortech Router and I’m replacing the breakout board. I can hook seems only the z-acid works. I can hook different axis to the z and they work, so I believe it’s just the breakout / controller board.
If I change the breakout/ controller board; will the steppers work with the new board as long as I keep the wiring the same? Have you had this problem?
