585,959 active members*
4,595 visitors online*
Results 1 to 8 of 8
    Jan 2014
    9
    wasino lj32-b
    hi all
    like a idiot i have gone and got a cnc lath cheep and now i am stuck the chuck when closed tells the machine it is open so i cannot get a run cycle to run
    as far as i can see it needs a parameter to change
    does eny one have a way of fixing this
    thanks
    WORK ALL DAY PLAY ALL WEEKEND
    Aug 2015
    21
    Re: wasino lj32-b
    Quote Originally Posted by steve brest View Post
    hi all
    thanks
    Try the in side clamp switch first
    Verstuurd vanaf mijn LG-D855 met Tapatalk
    Jan 2014
    9
    Re: wasino lj32-b
    Hi
    I have looked for a switch there does not seem to be one on the front panel or in the back panel.
    also i found that if you index to tool 1 it goes to tool 2 is this fixable or do i program around it
    thanks for the help
    Jan 2014
    9
    Re: wasino lj32-b
    Hi all now i must be a person looking for punishment got my lg 81 up and running after it has stood for 2 years in the back .
    Put power and every thing is there programs and offsets .
    Z axis not moving will sort it this week.
    It has a 3t control and no switch for OD--ID clamping
    Same as my lathAttachment 353638Click image for larger version.
    Aug 2015
    21
    Re: wasino lj32-b
    Well atleast you have the 0T control. You have a led with the label chuck unclamp. What happens when you clamp te chuck ? And it looks like you have lost some of the parameters.
    Jan 2014
    9
    Re: wasino lj32-b
    Hi when i push the peddle to switch it on the light on the panel comes on and the machine goes into a not ready state.
    I have got one way of fixing by changing the hydraulic pipes on the machine but it must be a different way of doing it .
    The perimeters have just been put back in and all seems to work.
    thanks
    Aug 2015
    21
    Re: wasino lj32-b
    There should be a key switch for the chuck. On my mori i have it around the hydraulic unit
    Jan 2014
    9
    Re: wasino lj32-b
    Hi
    I fixed the chucking problem all i did was change the pipes on the draw bar unit working now.
    So far so still no work been done on the mach i have not been able to program in mdi so i cant set the tools
    does some one know why
    thanks
  1. Wasino LJ103M
    By cmmachining in forum Fanuc
    Last Post: 02-23-2020, 06:05 PM
  2. Wasino L3-J3
    By BehrElec in forum Uncategorised MetalWorking Machines
    Last Post: 05-09-2010, 08:40 AM
